Old April 10, 2012, 08:16 PM
nasrott's Avatar
Default Thx Daz
D5 Tank kit arrived today, everything was on time and packed nicely, got it all installed, works nice. Temps around 50-51 with prime. Gaming on the corsair h100 highest temp was 61 so am impressed with temps with prime. Looks cool, even tubing is not that bad with 5/8"od. Forgot a trim piece on the block will install it once tear it down to install the razor once have some more funds.
Old April 10, 2012, 08:41 PM
ZZLEE's Avatar
Cool :)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old April 10, 2012, 08:54 PM
Keywork's Avatar
So....many....colours....
Friends don't let friends use onboard video.
Old April 10, 2012, 10:51 PM
IITSChiefII's Avatar
Nice temps, and damn that's a colourful build lol. Is that 24pin cable your using the Darkside sky blue cable from dazmode? was thinking about getting it myself.
Old April 11, 2012, 02:33 AM
nasrott's Avatar
ya that's the one from darkside, have a few green 6 pin ones also but this new card is 8/6 so one looks weird, ya like the color's, I know is a bit flashy, window in my case is small so only see a few things anyway, the block mainly. Have used lots of tubing in the past, uv blue , uv green, and black, thought red this time.
Was a bit concerned with the 5/8, but it looks ok, may still change it up to 3/4 not sure yet, black chrome fittings I like, compression also is cool, I usually use barbs. First time using 5/8 and compression fittings.
