Old April 10, 2012, 03:53 PM
Default fan direction on rad
Hi I have a liquid cooling unit and was wondering if its better to pull cold air from outside of the case instead of warm air inside the case. I dont really have an understanding of how these units work but I read that somewhere and was wondering if this matters or not.
Old April 10, 2012, 04:12 PM
Inside out.
Old April 10, 2012, 04:45 PM
KaptCrunch's Avatar
correct always pull outside air through rad then exhaust out rear of case or PSU fan suck it out
nets best proformance
Old April 10, 2012, 07:46 PM
Silent_Avenger's Avatar
Best performance is pulling cold air from outside the case. However, if you have a dusty room your rad fins will collect dust quite fast especially at lower fan speeds. If you have a fairly cool case or at least have one with good airflow that can isolate most of the GPU heat then you can take air in from the case and push it out allowing you to have dust filters on the rest of the case intake fans which won't affect the airflow over the rad.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
CPU rad fan air direction? Slik CPU's and Motherboards 8 November 8, 2011 12:11 PM
Don't know which direction to go (AMD or Intel) BootlegUsher New Builds 22 December 18, 2009 08:21 AM
Aren't they going in the wrong direction? redwagon Video Cards 19 November 13, 2009 01:51 PM
change the direction of my gx2 fan kyle_L Video Cards 8 December 18, 2008 02:35 PM
Need direction, help, insite......... Sitkaspruce Troubleshooting 6 April 26, 2007 08:40 AM
