Originally Posted by monkeyyy I was actually thinking of getting silver plated compression fittings instead of the barbed. Would this be sufficient instead of your "kill coil"?
So would you say that the RX360 has a lot of "growing room" such that if I up the anti to my build it wouldn't be a constraining point? |
Thw silver fitting will work just fine, I had the kill coil given to me, but had the silver fittings picked out to buy.
RX 360 is cooling a few peoples rigs an example of one, i7 930@4.2, SLI 480's and highest temps on the cards is around 50C. You should be able to cool any CPU, as well as 2 GPU's with ease.
