Old April 10, 2012, 05:13 PM
Originally Posted by monkeyyy View Post
I was actually thinking of getting silver plated compression fittings instead of the barbed. Would this be sufficient instead of your "kill coil"?
So would you say that the RX360 has a lot of "growing room" such that if I up the anti to my build it wouldn't be a constraining point?
It's not the RX360 that will grow it's the number of radiators that will grow. Rule of thumb is one rad (120mm) per major component. So the RX360 is essentially three rads worth.
So if your just cooling your CPU then RX360 is plenty, it's when you start going sli'd gpu's and motherboard mosfets and ram if you really find that necessary where things start to "grow" or your just a cooling whore and looking for the 1 degree
Old April 10, 2012, 06:26 PM
monkeyyy's Avatar
Yeah i've seen that rule quite a bit. I know it's a bit over kill but what the hay.
Old April 10, 2012, 06:39 PM
Adzsask's Avatar
GT AP-15's for sure, all I use after buying some once years ago, 3 on my RX 360 cooling my 130 watt i7, 42-43C load(folding@100%) in a 22C house, idles at 28C.
Old April 10, 2012, 08:12 PM
Precisely. This is what i'm working on right now Chomie Haf X Water Cooled
Total overkill but so much fun
Old April 11, 2012, 01:05 AM
Do you know where to get AP-15's? Or am I stuck in 2011 when they weren't available anymore.
**edit**
Stuck back in 2011.... LOL
OP, don't even consider coolant. Use distilled water only. Get some PT Nuke as well. Kills all bacteria. ;)
Old April 11, 2012, 05:19 AM
monkeyyy's Avatar
YES! I've seen this, looks awesome. I'm also trying to fill out a haf x, is that a Google sketchup model? Is it accurate with respects to the length of the rad? haven't done any measurements myself
Old April 11, 2012, 06:12 AM
nasrott's Avatar
just bought the raystorm.kit from daz think that is the way to go for sure pick the style maybe pay difference and jump to 3/4 od for fittings
Water Cooling Questions Astaroth Water Cooling 14 October 30, 2011 11:25 PM
New to water cooling, questions about fans. Yukonborn Water Cooling 7 February 2, 2011 05:57 AM
Water cooling Questions. Inate8 Water Cooling 2 July 20, 2010 04:26 PM
Questions on water cooling maintenance chrisk Water Cooling 27 March 16, 2010 12:31 PM
