Old April 2, 2012, 07:28 PM
thick rads are also much less restrictive and are usually quiter do to lower fpi
Old April 2, 2012, 08:29 PM
Ah wow, thanks for clearing that up.
Old May 10, 2012, 05:55 PM
the phobya rad comes with two mounting plates, and you can simply use strong double sided tape (3M "tape of the gods" Bill Owen from MNPCTech uses) to attach the mounting plate to the frame of the fan...i replaced the corsair stock fan in my 650D with a bitfenix spectre pro and its frame has plenty of surface area where the tape would mount nicely :)
i've seen this done in a few 650D builds...this one's the only one i can seem to find right now: Corsair Obisidian 650D Water Cooled Build - The Corsair Support Forums
Old May 10, 2012, 09:53 PM
mrjuggles's Avatar
I hope you post some pictures when this is finished. I myself just ordered the Phobya 200mm rad for my 650D. From what I have read I shouldn't have much of a problem getting it in.
I'm glad I found these big radiators, I'm fairly new to water cooling and had no idea they made 180-200mm radiators until a few weeks ago. I was originally going to build a 'basement' area for the 650D to stand on, and put a quad 120mm rad in there. The 200mm rad will save me lots of work, and now everything will fit inside the case.
Old May 11, 2012, 08:29 AM
i will personally be putting the phobya 200mm in my 650D sometime in June/July when i order my parts for watercooling :) will post pictures when it happens!
2x 180mm rad from magicool, available anywhere in Canada? Evochuck Water Cooling 4 October 20, 2011 11:09 AM
MagiCool XTREME QUAD 480 MarkOne Water Cooling 0 November 27, 2009 05:16 PM
Magicool CPU Block Review Discussion Thread Misoprostol Water Cooling 3 August 4, 2007 03:58 PM
