Old March 27, 2012, 08:03 PM
rfglass's Avatar
After a couple of hrs thinking , I pretty sure I have a Mod that will support my push/pull setup in the top of the case without losing the Aesthetics of the Corsair case. pic's to follow
Old March 29, 2012, 02:38 PM
rfglass's Avatar
Default mod so far
Took the top off a black case I had laying around,cut an opening 240x120mm in it intsalled a grill.The idea is to remove the grill from the corsair case,mount the push pull to the new piece I made,this gives me the extra inch I need to clear RAM on the mobo.The nice thing about it there will be no modding of the corsair case.I put magnetic strip on the bottom of the new piece to hold it in place.hopefully there will not be any noise due to vibration or another unforeseen issue.This is a work in progress,if it works I will clean it up to look like part of the case.
[FS] Corsair H100 bombdigiti Buy/Sell & Trade 0 March 19, 2012 11:27 AM
H100 trayton Water Cooling 19 March 5, 2012 12:55 PM
H100 Temps Flemminr Water Cooling 8 February 19, 2012 02:48 PM
H80 or H100 Reviews? PerryC Water Cooling 40 August 21, 2011 07:57 AM
