Old March 26, 2012, 10:44 AM
"Quote This..."
How can you say that more flow rate is better when the best performing block has the lowest flow rate? I've said this many times on this forum, coolant needs to spend time in contact with the heat source in order to pull in heat to vent out of the radiator. It also needs to spend time in the radiator to vent out that heat.
Black belt in CAPS LOCK.
Old March 26, 2012, 02:02 PM
Goofy Goober's Avatar
I think you are right, but the second block in the chart is the Koolance VID that has an average-high flow rate, so good blocks can have good temperature and good flow rate too. same for radiators, the RX series from XSPC has a good flow rate and deliver very good temperatures with low rpm fans
My watercooled rig: GUREN KNIGHTMARE
[Bundymania User Review] Mora 2 / Mora 3 / Phobya Nova 1080 and Supernova 1260 ! bundymania Water Cooling 5 February 27, 2012 08:07 AM
[Bundymania User Review] Tecnofront Torpedo Reservoir bundymania Water Cooling 2 February 21, 2012 09:06 PM
[Bundymania User Review] Microcool Benchtable Banchetto 101 Modular bundymania Water Cooling 1 February 16, 2012 08:32 AM
[ Bundymania User Review ] XSPC H1 Cube Case bundymania Water Cooling 3 February 15, 2012 04:19 AM
[Bundymania User Review] Triple Radiator (360) Roundup ! - 16 Rads bundymania Water Cooling 3 February 11, 2012 02:55 PM
