Hello All!
I am brand new to forums/building/modding/water cooling but I have decided to change all of those at once.
I have been on these forums, youtube, and other forums, absorbing everything I can about build specifications, loops, the steps, and ideas and have put all of the knowledge I have gained into a concept that's been building in my mind for month's now.
What I need now is for other's who have been there, done that, to assess what I have come up with and deem it plausible.
Below are hopefully Google Sketchup Drawing's that I have created showing my loop design and somewhat the structure of my build (** Please note that I am using other people's drawing's taken from
Here
And since not every component can be drawn I have used the closest resemblance of each part, the goal of this thread is to determine if my loop will work. **Also note that my motherboard is the EVGA Z68 FTW and will not include a block like it shows with the classified. I just used that board to match my color scheme (Red White Black)
Computer Components:
Case:
Cooler Master Haf X
Motherboard:
EVGA Z68 FTW
Processor (CPU):
Intel Core i7-2600k **Until I see what Ivy Bridge holds!**
RAM:
Corsair Vengeance 16GB (Black)
Video Card (GPU):
Nvidia GTX 580 3GB or
Asus Radeon HD 7970 or GTX 680 Depending on how the battle pans out!
Power Supply (PSU):
Corsair Professional HX1050 **I think 1200W is too much??**
Fan Controller:
Zalman ZM-FX1 Combo Fan Controller
DVD Drive:
Asus DRW-24B1ST Loop Components:
Reservoir:
Koolance RP-452X2 Rev 2.0 Dual 5.25"
Radiators:
XSPC RX360 and
XSPC RX240
CPU Block:
XSPC RayStorm
Pumps (x2?):
Dazmode STORM D5 VARIO 8-24V ** Supposedly these are the same as the Koolance or Swiftech D5 Pumps? Just cheaper?
GPU Block: To be determined base on GTX 680 reviews, I will either be going a single GTX 680 or single Radeon 7970 for the time being with the ability to upgrade to a second card (hence the somewhat overkill setup) later down the road.
Connectors: Bitspower (Black) (Compression) **See cost chart below for detailed selection**
Tubing:
PrimoChill Primoflex Pro LRT UV Red 1/2" ID - 3/4" OD Tubing
Fans:
Scythe Gentle Typhoon 1850RPM The Concept:
My Design is based off the
Koolance RP-452X2 Rev 2.0 Dual 5.25" Bay Resevoir Which from my understanding is a dual loop capable reservoir with the ability to run the bays in series.
Going to the drawings I'll walk you through how I want to set it up:
**Note: I marked two tubes as blue representing "cooled" water from the rads, hopefully that helps decipher the direction of water. If not I'll do a picture up with arrows later...
**PX[IN/OUT] refers to the ports of the Koolance Reservoir seen in image #4
**Shown in drawings is Koolance Reservoir Rev 1.2, it seems that the concept will work with Rev 2.0
the ports are just in a horizontal line behind the pumps
LOOP
1) Starting at the reservoir water will exit out of P1[OUT] and enter into the RX360 rad
2) Output of RX360 enters RayStorm CPU block
3) Output of CPU block inputs to P2[IN] (Res)
4) Output from P2[Out] enters RX240 rad
5) Output RX240 rad inputs to GPU block
6) GPU block output enter P1[IN] (Res)
I chose to do a single crossover loop (As I am going to call it) because it gives me the ability to drain the entire loop
(Drain will be located down and behind the RX240 rad) in one go. Also, I like the idea of shared water between the CPU
and GPU and the fact that the loops will be working together instead of one loop being under more stress than the other.
Cost Spread Sheet:
This is what I've calculated it'll cost to build this loop, it's seems a little high but I guess that's because
of the compression fittings? I'll be using DazMode.com and NCIX.ca for the tubing:
Questions:
1) Can I get away with only a single D5 pump? I read through the koolance manual and it is possible
to run such a configuration (series bay) off one pump, but I'm not sure if I will be able to do it...
Reasons for doing so: It's cheaper, and probably quieter.
ANSWER: Yes, from feedback
2) Can the RX240 be put where I have it? I have seen it done multiple times but they modded the
bottom of the case which is what I was planning to do in the first place, but I still wanna be able
to use to drive bays where the RX240 is sitting in? Any other rad placement suggestions
Things that may be brought up:
1) I don't need the RX240 on the bottom its overkill:
-Yes it is but I am planning for the future when I feel it necessary to add a second gpu in sli
and wanna be able to tweak the loop slightly with having everything else ready to go (Hence
the reason for me wanting to just run off one pump if possible...)
**Will continue to update**
Please throw some comments about what you like and what you don't like that's what this is all about!
Just keep it positive... if I screwed up tell me but give me a solution.
Cheers,
Chomie.
