Old March 20, 2012, 10:33 AM
Ok I watched all of the dazmode videos last night. I'm starting to feel that a custom DazMode Raystorm kit is perfect for my needs.
One question that I thought of last night though...
Coloured tubing or coloured liquid? Which do you prefer and why?
Old March 20, 2012, 10:53 AM
SugarJ's Avatar
Clear tubing, premixed liquid. If you go through my old build log, you'll see the red tubing I started with, then the clear tubing with Feser UV Red coolant. It looks so much better, IMHO. And with all the colors available now (Mayhem's anyone?) you can change your loop color easily with a good distilled flush in between.
SugarJ's "Nemesis Reborn" or just another TJ07 build
Old March 20, 2012, 11:24 AM
Thanks SugarJ! Yes the coloured fluid does look much better.
Is there a particular brand that is a favourite to many? I want blue.
Old March 20, 2012, 09:23 PM
The Fesser 1 Blue looks pretty nice. I was using the Fesser red before I switched to Ice Dragon
Asus Rampage IV Extreme | Intel i7 3930k | Crucial 4x4Gb | OCZ Vertex 3 MaxIOPS 240GB | WD Velociraptor 1TB | AMD R9 290 Crossfire | Win10 Pro 64 | EK Supremecy | 2 x Alphacool XT45 360 | 2x Liang DDC 3.25 | Swiftech Malestorm Res | Case Labs M8 |
Old March 20, 2012, 11:14 PM
Originally Posted by Pabz0r545 View Post
Can anyone chime in on what pump/res style they prefer and why? I'm still really indecisive about this.
For looks I prefer a cylindrical res but it does take space in a case. When space is tight I go with a bay res. Easy to bleed/fill and doesn't take space in the case....but I don't feel like it looks as good as the cylindrical ones
Old March 21, 2012, 12:28 AM
Found this on bit tech, might help in your coolant search
What is the best UV water-cooling coolant? | bit-tech.net
Old March 21, 2012, 07:03 AM
Hello, maybe research colored fluid a little more... I have done a lot of research and there's mixed results about it with the possibility of staining your components and leaving residue in your blocks causing blockage... I'm working on a concept right now go to the watercooling section on this forum and click on the Haf x concept loop thread, it's one I made a couple days ago see if you can take any ideas from that!
Cheers,
Chomie
Parts selection help Yeno New Builds 8 July 5, 2011 02:01 PM
Need advice, VC selection KRAFTIG Video Cards 18 September 19, 2010 07:09 PM
Seeking advice on part selection Mibs Water Cooling 26 February 8, 2009 02:52 PM
Need advice on parts selection and purchasing Neutronium New Builds 10 January 9, 2009 01:12 PM
Need Advice on Parts Selection. BALISTX New Builds 16 August 13, 2008 12:00 PM
