Old March 9, 2012, 12:39 PM
Default Do new rads still need to be flushed?
i remember that rads need to be flush heavily before it can be used (XSPC being the worse offender). Is this still the case? Do i need to do the isopropyl alcohol or vinegar flush in modern rads?
Old March 9, 2012, 12:49 PM
Yes they need to be flushed most people just use really hot water.
Old March 9, 2012, 12:59 PM
lowfat's Avatar
Just use hot water.
Mael
Big Lian Li
Forever Alone
AmuseMe's Avatar
You bet they do! Even if they say they have been, you still will want to.
Old March 9, 2012, 02:40 PM
dandelioneater's Avatar
What I like to do is fill them almost full with hot tap water, plug both ports and shake em around to loosen any debris, then give them a rinse with distilled.
Old March 9, 2012, 04:13 PM
Amarthfea's Avatar
I bought a brand new ek 420 rad last summer so thought I would do a flush just in case, it actually had a fair amount of crap in it, despite the ends being plugged.
I just boiled distilled water, then used a sterile funnel, and poured it in. capped all ports, shook like mad with over gloves on, and poured into a glass bowl.
repeat until crap stops appearing bottom of glass bowl, this rad took 4 flushes before I was pleased. Then rinsed, again with distilled water, and shook all excess water out, and put in loop.
~Elysium, I behold your beauty...
Old March 9, 2012, 07:45 PM
AmuseMe's Avatar
Even if it stops coming out, more is in there ;)
Old March 10, 2012, 05:43 PM
Personally i bough a filter. Its good to clean the loop. Yeah i usually flash them with hot water and that it Dry.
mixing rads Raftus Water Cooling 3 December 8, 2012 05:30 AM
D5 w/ EK top + 3 x 360 rads Prolab Water Cooling 6 October 21, 2011 07:14 PM
how many rads can a 655 push through Shadowmeph Water Cooling 40 September 20, 2009 10:08 PM
Circuit City Flushed Down the Drain FiXT Press Releases & Tech News 23 January 22, 2009 11:02 AM
Two Rads? Infiniti Water Cooling 20 June 14, 2008 05:55 PM
