Old March 21, 2008, 04:16 PM
ChuckleBrother's Avatar
Default Good GPU Block
So yeah, as stated, what is a good GPU block, for an 8800 Ultra, something to go with the PA120.2(dunno if its copper or aluminum).
Whats the best one I can buy(under $100)?
"...you play a mean banjo"
Old March 21, 2008, 04:52 PM
Apollo4g's Avatar
I will say EK FC block found at NCIX.
You ca price match it for about $100
And the Thermochill rads are brass pipes with copper fins btw.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old March 22, 2008, 05:08 PM
Hmm, it says the threads are 1/4", do I need special fittings for my tubing since my tubes will be 7/16"? Also, do I need any sinks for the memory or something?
Um, also, if I have 1/2" barbs, I should be going with internal diameter of 7/16" right? Do barbs usually list inner or outer diameter?
Old March 25, 2008, 08:54 AM
lcdguy's Avatar
the 1/4 thread size has nothing to do with the pipes thats just the thread type that is used to screw the barb to the block. you could have a 1/2, 3/8, etc barb while both have a 1/4 thread.
Old March 25, 2008, 12:55 PM
Thanks, yeah, I noticed when I was looking at barbs, it has them listed like: G1/4,G3/8 etc, got my stuff all squared away, just waiting for my paycheque before I start blowing cash:).
Old March 30, 2008, 11:45 AM
biff's Avatar
If it were me I'd get something more generic like the DD Maze 5 or Swiftech MCW60. They're less than half the price of a full coverage block and will cool the GPU just as good too. Of course you might want to get some f those stick-on ramsinks for the vram. Another bonus besides being muuch cheaper is that they can migrate to another card with little to no trouble, the full coverage blocks are onetime use only unfortunately.
Just my 2 cents,
Ryan
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
