Old March 2, 2012, 11:23 AM
Default 2 or 3 slot spacing?
I was wondering if I need a 2 or 3 slot spacer to connect 2 gtx470's using aquacomputers full cover blocks on this board.
Old March 2, 2012, 11:32 AM
bissa's Avatar
if you're using water cooling, you can have them as close as you want. the spacing thing is for air cooling, so that there's room for airflow to get in between the 2 cards.
Old March 2, 2012, 04:52 PM
Silent_Avenger's Avatar
It's also to allow people to buy those 2.5 slot cards that will take up 3 PCI slots and xfire or sli them in the proper slots.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old March 3, 2012, 03:44 AM
PLg PLg is offline
The answer you are looking for is 3.
It is the 3rd slot above the initial one
Old March 3, 2012, 07:58 AM
techman95's Avatar
for the 990fx sabertooth you use the two tan slots and then the dark brown slot. you dont want to use the black one for graphics card because it is an x4 pci-e slot. so 3 slot spacing. i didnt even have to read the manual for mine just look at the under side of the board and youll see its only x4 wired, who needs manuals
Amd....definitely a blond female.....not much on the cpu side, but always strutting about showing off her gpus
EK gpu blocks + bridge spacing jibz Water Cooling 1 January 7, 2012 06:37 PM
EATX standoff spacing magictorch Troubleshooting 1 December 25, 2010 12:36 PM
[FS] FS: Feser X-360, 17mm spacing bernZ Buy/Sell & Trade 4 November 6, 2009 08:08 PM
Good Crossfire Board - Slot Spacing Issue element291 CPU's and Motherboards 1 March 3, 2009 06:49 PM
