  #21 (permalink)
Old March 6, 2012, 05:17 PM
Why 3 Pumps, Why not! My old setup had 2 mcp35x, one stand along and one built into the rad.
When picking out parts i was going to stick with 2 pumps but then the dual version came out and it was just a better deal to get the x2 with pumps than the x2 with only a single pump.
The other reason is noise, 3 pumps gives me a lot of room to control how i want the system to run. I am using Aquacomputer 5 Pro to control the system and with 3 pumps i can run them at min (1300 rpm) and get 0.5 GPM or all the way up to 4400 rpm and get 2.4 GPM. So i can go from dead slient to ejt taking off depending if im just pissing around or going for a new benchmark highscore.
Plus i think it looks pretty sweet.
For the pumps they do need to be primed with the case tilted for the first time but i have never had a setup that was just pore water in and good to go. Actuall this was the easiest time i have even had priming a system.
As posted above, the res has a clear tube in it so you can use the top ports as inlets.
The setup looks like this
RES->X->360RAD->X2->120RAD->CPU->VID->VID->RES
I would love to have the 120 rad after the cpu but this setup gave me the best flow for tubing only needing 3 45 deg connectors.
Heres some more pics i took with a little more time than the last ones.
R/C Toys omgwtf Off Topic 6 February 11, 2012 01:42 PM
New Toys lechumbl Off Topic 6 November 8, 2011 09:56 PM
Buying parts tomorrow for SB tomorrow! tl9015 New Builds 2 January 16, 2011 04:05 AM
New toys... cul8erppl Case Mods, Worklog & Gallery 3 September 4, 2010 06:38 PM
One of my new toys mklym Mobile Computing 5 January 16, 2009 10:41 PM
