OK, I promised pictures of this once I got it all installed. I finished it up yesterday and just got finished leak testing for ~20hrs. I removed the drive cages and installed the MCR220 radiator up front with the 2 fans pulling through it. On the backside of the cage, I mounted a MCP355 and I am using an Apogee GT waterblock. I wasn't gonna bother with a reservoir, but I do prefer them for the added simplicity of bleeding the air. Here's the pics:
Keeps my CPU @ 33C idling @ 3.5GHz w/1.28V Vcore and 45C under PRIME95 same settings. I haven't tried pushing the CPU much since I got it, one of these days......
Nice! but man, that noctua is UGLY. Maybe paint it green!
__________________ The Vortex H20
EVGA SR-2 Classified
2 x Xeon L5639 Hexcore CPUs, 3.2GHZ
EVGA GTX 580 - 940/2115
24GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 90GB Corsair Force SSD RAID0
Sharp 32" Aquos 1080p
Benq W500 Pojector.
Watercooling:
2 x EK Supreme HF, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, XSPC GTX 580 FC block, EK Coolstream XT 220 RAD Gelid Wings Push - CM R4s Pull.
Yeah, 3/8" tuning keeps within 1-2C of 1/2" and is easier to deal with too. As for the HD's, you could always get 3 sets of the adapters I used and mount 3 drives. The space is there, it would just be a touch tighter. And finally, yes Noctua fans are not that pretty but they sure work well!
Removing the drive cages really opens up this case. For me only having one drive is no big deal since I am in the process of putting together some NAS storage. I would rather keep my PC simple and also less heat dump from less HD's.
Just goes to show that b1lk1 leans toward the practical.
I myself can't get past those fugly noctuas, good as they are. If they just made a simple black one I'd toss all my blue led cooler masters and go noctua.
Looks awsome, but what kinda NB heatsink/fan is that? The thing is massive!!! Looks like pure Cu with a 80mm fan on it? Huh??
That is the stock heatsink with the auxilliary fan they give you when water cooling. I agree that it is gigantic! Seems to work well enough though. I am running 1.44V through the chipset and the FSB @ 380.
Having said that, it's still a nice rig.
It is a great and QUIET fan. I don't think they are that ugly, but I agree that I do lean towards the practical more than the looks.
