Old March 20, 2012, 11:19 PM
Originally Posted by KaptCrunch View Post
3/8 id 1/2 od 1/16 wall to flimsy
3/8 id 5/8 od 1/8 wall OK
I agree. Especially if you have tight bends to do, you'll be glad you have a thicker wall.
Old March 26, 2012, 04:36 PM
If you google it you'll find that tube diameter makes a pretty negligible difference in cooling performance, so I'd go with whatever you find the most aesthetically pleasing / available. I personally like 7/16ID tubing over 1/2 barbs (and zip ties to secure) as I think it's the most cost-effective solution.
Primochill Tubing or any good tubing with thick walls in Vancouver Lower Mainland? bjornbjorn Water Cooling 5 January 26, 2012 05:19 PM
Red Tubing? Amarthfea Water Cooling 11 August 27, 2011 05:51 PM
tubing Ken_C Water Cooling 3 January 10, 2010 11:26 AM
Where to buy WC tubing? sinn98 Water Cooling 8 August 24, 2009 06:55 AM
Tubing, tubing... what to choose? Dazmode Water Cooling 16 June 23, 2009 02:32 PM
