Waterblocks that work with Asus M5A99X-EVO Wifes system is coming together but she wants to board to have fancy water lines as you puts it haha, so is there any blocks that will work well with that board? Thanks :) |
EK has a south bridge block that will fit. But it would be pretty wasteful as the chip likely doesn't throw enough heat to require one. But otherwise you are likely out of luck. As for CPU blocks, any block w/ AM3 mounting will work. |
Some members here hooked me up with good CPU blocks so shes set there but for the Chipsets she needs some. maybe its time to build stuff again like the good old days haha |
