Old February 20, 2012, 08:05 PM
Default Want to replace my 360 rad
I've been using a used 360 rad for some time now but would like to replace it with something new. I like to overclock my cpu and VID card. Currently using the raystorm on a crosshair V and I'm just wondering what people would be using if they had the choice. I use quiet low RPM fans as well.
I like shopping with Dazmode but I'm always open to suggestions.
cheers
Mah Rig now
Mah Rig before
My stuff for sale.
Old February 20, 2012, 08:35 PM
lowfat's Avatar
What do you have now? Don't expect to get huge gains by getting a new radiator. It isn't going to be more than 1-2 degrees in difference. But if you are also doing it for aesthetics then look at the XSPC RX360. It is a great radiator w/ a low FPI for low speed fans.
Mael
Big Lian Li
Forever Alone
Old February 20, 2012, 09:30 PM
Adzsask's Avatar
I'm guessing an XSPC RS/RX 360, and if it is the RX like I have, your going to have to shell out some major cash to get a boost in performance from the same sized rad.
The price will hurt your soul a little, but this is the top dog short of limited edition rad.
Aquacomputer_Airplex__360_Radiator_-_Copper_Fins_-_Dual_Circuit_
Or this beast
MagiCool_Limited_Edition_Monsta_420/360_Triple_120mm_140mm_Xtreme_Performance_Radiator
Old February 20, 2012, 10:17 PM
adding a second rad
replacing a rad for 1-2c
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old February 20, 2012, 10:25 PM
I am just waiting for my Black Ice SR1 360, i think that rad or as other have mentioned the RX
Old February 21, 2012, 07:53 PM
Thanks for the posts.
I'm not really looking for huge temp decrease just wanting to actually buy a NEW rad. The one I have is used and bashed up a little but I couldn't afford a new one when I built the loop way back when. I'm more concerned about this one getting leaky while I'm working out of town. It's a folder ;)
God that Aqua rad is pretty schweet
Mah Rig now
Mah Rig before
My stuff for sale.
Old February 21, 2012, 09:35 PM
I had to hold off on that aqua rad... it was sooo tempting if the price wasnt 1 1/2 times more than my next choice
Old February 24, 2012, 06:06 AM
Wow that aqua rad is sick.. but damn expensive.
Old February 24, 2012, 09:40 PM
matari's Avatar
HW SR-1 prolly best choice for low RPM fans. Just be warned; the radiator has a shroud and forces you put fan one side.
Old February 25, 2012, 08:32 PM
howpet's Avatar
cheers
Rads don"t just "spring" leaks. You can"t get much better cooling than a 360. Hate to say it but you"re probababily setup for the next 10 years or more. Flush the rad, flush and clean the heatsink blocks, new tubing..If you"re into UV.
There"s very little or no pressure in a W/C loop so the rad is the least or last thing to give you problems. Since it"s an older rad the build quality is probably quite good and the upgrades you"re wanting or cooling upgrades should be maybe acomplished thru new waterblocks, but for the loonies you probably won"t notice much difference...and you"re cpu certainly will not!!
Replace HDD? Hunt Storage 11 February 15, 2010 12:33 PM
[WTB] Looking to replace what i lost Beermaster Buy/Sell & Trade 9 October 14, 2009 10:27 PM
Replace GPU sticker... mattlef Off Topic 4 September 28, 2009 07:43 PM
Some new parts, to replace old ones AmuseMe New Builds 9 July 6, 2009 01:45 PM
Replace TIM on gtx275? somecanadianguy Video Cards 6 June 19, 2009 10:51 PM
