Need to update my Watercooling So i've got a no name Rad, banged up a tad some of the fins are bent etc What i got Banged up no-name Rad 240 EK Supreme LT Nickel / Plexi No-Name Pump Swiftek Square Res Tygon 3/8" ID Tubing Thermaltake Coolant What i want XSPC RX240, 63mm Thick compared to 45mm no name one i've got Performance Dual 120mm Radiator XSPC RX240 Performance Dual 120mm Radiator XSPC RX240 [RX240] - $73.99 : DazMode, The Best Canadian PC Watercooling and Modding Store! So plans have changed.. i will be making a Dual loop setup for my 5970 alone and Mosfet / CPU on the other EK Spin Bay Black Swiftech MCP355 Pumps XSPC DDC Plexi Performance Top XSPC Performance 65mm Dual 120 Radiator 16ft of TFC 3/8" ID Red Tube 12x Straight Compression Fitting 3x 45 Degres Compression Fitting 4x Barb Clamps Dazmode Protector Indigo Xtreme™ Thermal pad LGA 1155 All from our DazMode store 480$ Shipped / Taxes Will be getting a EK WB for my 5970 and also a EK Plexi Mosfet from another member here any other recommendation ? its just a question but i've got a DDC pump with Acetal top that i've planned on my build after the video Daz made and thinking of using the bay res + making a hole in my 5.25 bottem bay and putting the tube threw it and mount my pump underneath the 5.25 for less clutter This is a layout on paint i've made to show what i what to do http://img191.imageshack.us/img191/6...looplayout.png |
Updated |
Hmm, Personally I don't see many benefits to having dual loops especially for the massive increase in cost. Did you consider doing a single loop with single pump? Also depending on the fans you're using the EX series from XSPC has been shown performing slightly better than the RX at higher fan speeds and I believe the EX is cheaper. If you're using slow fans then the RX is one of the best on the market. |
been told by lots of ppl that my 5970 would heat up the water too much on a single loop.. so i'd rather run a dual loop so that my GPU is alone so i can maximise my overclock on it Once watercooled.. i'll be heading for the 950Mhz Core and 1350Mhz Memory mark from 800Core / 1100Mem with fans at 60% Also i know its not good.. but while gaming my i5 runs at 60-65degres but while using Intel Burn test / Prime95 goes up to 80degres and that's also why i want a dual loop Video lop is uploading atm |
Whomever is telling you that is someone you should probably stop taking advice from. |
+1 I suggest single loop with two pumps (in serie) for redundancy and add radiators to get to your targetted delta T (water T- ambient T = delta T). |
the one who gave me the advice is the one who had a 5970 watercooled and said that he had to switch to a 1 loop because the 5970 was heating up the system too much because of the heat they generate |
O_o I have 3 gtx 570 at 1.1v heavily overclocked in my single loop and the delta before and after the cards is negligible. Maybe you're friend didn't have enough air flow/pressure to get air through his rad? |
I like to use a single loop, just because it is cleaner and easier to do. I personally would use two pumps (for redundancy. If one dies, you have the other one going still.) Also, just make sure you have enough radiator (with good fans) |
| All times are GMT -7. The time now is 09:14 AM. |
