Old February 14, 2012, 10:57 AM
Default Is it possible...
... to have two different colours for liquid and tubing, and have both show their colours with UV?
Old February 14, 2012, 11:02 AM
KaptCrunch's Avatar
yes in separate loops meaning 2 of everthing with using 2 VU fluid colours
but if using the different UV tubing your only using 1 of loop things
Old February 14, 2012, 11:35 AM
Well, what I was thinking of doing is having UV orange tubing, but with UV blue liquid flowing through it. In which case, the surround edges of the tubing would glow orange, but a bright blue would theoretically be showing in the center of the tubing. They'll both be in one loop, but two different UV colours that would (hopefully) show.
Old February 14, 2012, 12:14 PM
SugarJ's Avatar
You'll probably only see the tubing color.
Old February 14, 2012, 12:20 PM
Damn Oh well, back to the drawing board, I guess.
Old February 14, 2012, 02:39 PM
Unless you had a tube in a tube, then you might possibly see the different coloring, but one would have to be much more reactive then the other. Maybe they make a chameleon type UV reactive that can change depending on the light being shone into it?
Old February 14, 2012, 03:35 PM
Nah, I don't think there is. I've been looking high and low for information on it, but seeing how scarce it is, I'm assuming it's not doable.
In any case, I think I know what I'm going to do: Strategically put orange LED's in the forefront of the case to shine off the tubing, and have UV lights in the background to cause the UV blue liquid to glow. Not sure how well it'll work, but I think that's the best option I have to get something similar to what I want. Worse comes to worst, I'll just ditch one of the two LED's and call it a day
Old February 14, 2012, 06:27 PM
I have seen a case where someone used a clear uv reactive tuping with green liquid, thanks to uv light it looked like blue on the outside and green inside. Maybe you can do something like that?
the tuping was clear- blue uv reactive.
Old February 15, 2012, 09:24 AM
Interesting... Just checked it out. Seems Daz has some 1/2ID clear/UV blue tubing. I was hoping for the tubing to be orange and the liquid blue, but I guess this is a good compromise if it works.
Thanks for the tip
