-   -   Recovered Coolit Omni (http://www.hardwarecanucks.com/forum/water-cooling/51561-recovered-coolit-omni.html)
xilocient February 13, 2012 01:46 PM
So I've got a 5870 block and rad recovered from a coolit omni that had a leak in its pump seal. I was thinking of putting my 5870 under water with the omni, but I obviously can't anymore. That said, I've been bitten by the water cooling bug.
What would you do with these parts?
ilya February 13, 2012 02:05 PM
If the pump is working and you have the tools, I would try resealing and refilling/bleeding it.
But on second thought it might be under warranty still. The Omni's were released just over a year ago and didn't see availability until well after that IIRC.
xilocient February 13, 2012 02:15 PM
The pump's dead and there's no warranty. When I got the unit, there was green coolant all over the foam packaging. When I took it apart, there was almost no coolant left inside and I eventually figured out that it leaked out of the pump.
