<~----> water cooling check list - Hardware Canucks
Old February 12, 2012, 07:10 PM
QuickDeath's Avatar
Default water cooling check list
okay soo i am thinking of getting into water cooling but i would like to buy bit and parts at a time, does anyone have a check list of what all i will need to point me to a site that might have a check list so i know i have gotten everything
Old February 12, 2012, 11:23 PM
Birk's Avatar
Water Blocks (CPU, GPU Optional)
Pump, Grab a D5
Reservoir (many options)
Tubing. Comes in many sizes.
Radiator - 120, 240, 360, 480 (Basically go for 120mm per block minimum)
Fittings, (Barbs or Compression fittings, 2 per item) - Keep in mind if you use compression fittings you'll need to know both Inside Diameter ID and Outside Diameter OD of your tubing.
Check out Dazmode - Canadian Watercooling Store, Reviews and Community and watch his videos and check out the premade kits he's got listed they'll tell you a lot of info about what to get.
-- Main System --
THERMALTAKE Chaser MK-1
ASUS P8Z68-V Pro / Gen3
INTEL Core i5 2500K @ 4.5ghz 1.35v
- XSPC Raystorm
DIAMOND Radeon HD 6950 2gb @ 840/1325
- AQUACOMPUTER AquagrATIx Full cover Block
CORSAIR Vengeance C9 16gb (4x4) 9.9.9.24
OCZ ZX 850w Gold
WD 320gb, 1Tb, 500gb
LG 22x Super Multi DVD
Old February 13, 2012, 10:39 AM
Take a look at the Swiftech Edge HD kits, they can start you off with the basics and from there you can add blocks or extra rads when you need them... Swiftech H2O-x20 Edge HD - PC Liquid Cooling Systems CPU Cooler VGA Water Block Heatsink Pump Radiator Heat Exchanger Kit
Old February 13, 2012, 11:32 AM
dandelioneater's Avatar
Compression fittings are nice to have. In addition to dazmode's videos which are really good, you can also check out linus tech tips watercooling videos. He did an update not too long ago. Do you have a big case? Make WC so much easier.
Old February 13, 2012, 12:40 PM
QuickDeath's Avatar
yes i am running a haf 922 i hope its big enough lol
Old February 13, 2012, 05:04 PM
QuickDeath's Avatar
i really like that Swiftech kit has only ever used or own one? just trying to get some ideas.
Old February 13, 2012, 05:55 PM
jtf2's Avatar
imo do not buy a kit,cause you will want to be upgrading in no time.
Old February 13, 2012, 06:14 PM
Birk's Avatar
if you want to be able to upgrade you can still get something like a raystorm kit that uses standard fittings.
-- Main System --
- XSPC Raystorm
OCZ ZX 850w Gold
Old February 13, 2012, 06:27 PM
QuickDeath's Avatar
well its not a extreme build its only a i3 lol, just kinda get my feet wet
Old February 13, 2012, 06:52 PM
Birk's Avatar
I see what you did there, But really, if you're feet get wet your doing it WRONG!
-- Main System --
- XSPC Raystorm
OCZ ZX 850w Gold
Please sanity check my gaming PC parts list phipster New Builds 12 January 1, 2012 10:24 PM
HAF 932 Water Cooling miggs78 Water Cooling 7 January 3, 2010 11:17 AM
Water Cooling Kit AmuseMe Water Cooling 9 July 12, 2009 11:11 AM
List of Water Cooling Guides rk Water Cooling 0 February 18, 2009 01:09 PM
New to water cooling coreyb Water Cooling 14 April 10, 2008 12:55 PM
