Old March 18, 2008, 02:56 PM
BALISTX's Avatar
Default SLI Water Cooling.
What parts or prefab kit would one recommend for a SLI water cooling setup? Looking at spending no more than $250-$300
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old March 18, 2008, 05:01 PM
Cptn Vortex's Avatar
Hmmmm. CPU too? The Swiftech H20-220 Apex ultra + kit. It can be had for about $275 when on sale, and with that add a second GPU block, about $40 Extra.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old March 18, 2008, 05:35 PM
3.0charlie's Avatar
I agree. Great kit.
Old March 18, 2008, 07:35 PM
BALISTX's Avatar
Will those GPU waterblocks work with the 9600 GT? I was thinking about maybe doing a two rad setup. One Dual fan for the GPUs and a single for the CPU. I have a Coolermaster CM690 and was thinking about putting the dual rad up top where the two top 120mm exhaust fans are and the single on the back where the 120mm exhaust fan is.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old March 18, 2008, 08:12 PM
Fitting a rad up there will be tight.... not much room.
Yes, I am pretty sure they work with the 9600GT, as it is essentially the same as a 8800GT, which uses the same mounting as the 7900 etc... all compatible.
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old March 19, 2008, 10:02 AM
lcdguy's Avatar
if it were me i would get 2 D0tek Fuzion gpu blocks, ram sinks, mcp355 or 655 pump, 1/2id tubing thermalchill rad 120.1 or 120.2. but thats just me.
