  #21 (permalink)
Old March 19, 2008, 09:53 AM
Cardboard box with DSL's Avatar
I'm guessing they acquired a license from Lian-Li to use their design for the case...
I just want to double check, will the tubing that I chose work with my barbs and such?
  #22 (permalink)
Old March 19, 2008, 10:00 AM
lcdguy's Avatar
You may want to also check out the moutain mod cases ncix. these cases are awesome. I plan to get one this summer so i can water cool my gaming rig. I believe some of theri models allow you install the PA120.3 Internally Not exactly elegant but pretty cool looking. Plus the paint job is powder coat which is awesome.
  #23 (permalink)
Old March 19, 2008, 10:02 AM
3.0charlie's Avatar
Some models of the MM cases have the internals designed to fit the exact same rad (PA120.3).
Hydro-Quebec is salivating...
  #24 (permalink)
Old March 19, 2008, 10:06 AM
Truthfully, I don't really find the mountain mods cases all that attractive. The whole cube thing doesn't really sit well with me...
  #25 (permalink)
Old March 19, 2008, 10:12 AM
Now that everyone has their hate on for me since I admitted to not like MM cases that much, can you guys recommend me some good fans for the radiator?
I was thinking Noctua, Yate loon or S-flex, on a fan speed controller....
  #26 (permalink)
The Tagan Black Pearl is a Lian-Li. It is essentially a Lian-Li OEM sold to Tagan. Tagan does NOT make their own cases.
Closest case to the Black Pearl is the V2000
Daily // 2.4GHz Mac Mini ::4GB :: 320GB HDD :: Apple Wireless Keyboard :: G5v2
Rig // PC-A7010 :: 1050W :: Rampage :: Q6600 :: 8GB :: GTX 260
X25-V :: 4x 1TB RAID-5 :: 2x 1TB RAID-1 :: 4x 1.5TB :: 1x 2TB
G15v2 :: MX-518 :: Xonar DX :: 7 Pro x64
2408WFP :: DT770/80 :: Onkyo TX-SR605 :: Klipsch RB-61 :: SVS PB10-NSD
  #27 (permalink)
Old March 19, 2008, 10:18 AM
3.0charlie's Avatar
Thanks for the info - there were too many similarities. Looking at the pics, the build quality does not look to be on par with a Lian-Li case though.
  #28 (permalink)
Old March 19, 2008, 10:42 AM
I'm pretty well ready to order now, any last minute suggestions?
Pts Petra PT_NUKE Concentrated Biocide Water Additive for Water COOLING(10ML)
In Stock 25454 $4.99 $4.99
Swiftech APOGEE GT S478/LGA775/S754/S940/S939/AM2 3/8IN & 1/2IN &1/4IN Barbs
In Stock 22287
$35.20 $35.20
Swiftech MCR320 Quiet Power Water Cooling Radiator Black G1/4 Threaded
In Stock 20090 $41.68 $41.68
Primochill PC Ice NON-CONDUCTIVE Water Replacement 32OZ - Invisible Blue
In Stock 28632 $7.99 $7.99
1 x Primochill Invisible Blue Dye Bomb Water Additive for PC Ice PC Pure Utopia or Water
1 x Primochill PC Ice NON-CONDUCTIVE Water Replacement 32OZ - Clear
Masterkleer Pvc Tubing 7/16IN ID 5/9IN OD 10 Feet
In Stock 21318 $5.99 $5.99
Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings
In Stock 20091 $18.70 $18.70
D-TEK Customs 1/2IN G1/4 Chrome High Flow Barb Fittings (Pair)
In Stock 24355 $5.99 $5.99
2x Antec Spot Cool Adjustable System Cooler Blue LED 3 Speed 2000-3000RPM 23-33DBA 15-22CFM
In Stock 21935 $11.99 $23.98
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
In Stock 19862 $64.11 $64.11
Tagan Black Pearl Full Tower E-ATX Case Black 7X5.25 8X3.5INT No PS Side Window
In Stock 24802 $215.99 $215.99
Swiftech MCB-120 Radbox Revision 2 Black
In Stock 19860 $14.54 $14.54
Polypropylene T for Water Cooling T Line 1/2IN Barbs
In Stock 19709 $3.99 $3.99
Sunbeam 4 Port Rheobus Fan Controller Kit Black
In Stock 10225 $11.93 $11.93
3x Yate Loon D12SL-12 120MM Quiet Cooling Fan 1350RPM 47CFM 28DB 3PIN & 4PIN Sleeve Bearing OEM
In Stock 22644 $4.13 $12.39
Check to delete an item
Total BEFORE Price Match $541.64
YOUR TOTAL $467.47
  #29 (permalink)
Old March 19, 2008, 11:55 AM
Parts have been ordered! Now its time to head off to home depot to pickup a few bits and pieces.
Thanks again for all your help!
Heres my final list
  #30 (permalink)
Old March 19, 2008, 12:49 PM
lcdguy's Avatar
i didn't say they looked elegant, i just sai they could lots of Stuff :D.
