Old March 18, 2008, 08:03 PM
Originally Posted by Cardboard box with DSL View Post
Empty_Quarter, as long as you dont mind my copying your design, I'm pretty sure that I'll go for the TJ07 now...
I think I found your build log the other day, and it got me hooked on the TJ07.
Go for it
Daily // 2.4GHz Mac Mini ::4GB :: 320GB HDD :: Apple Wireless Keyboard :: G5v2
Rig // PC-A7010 :: 1050W :: Rampage :: Q6600 :: 8GB :: GTX 260
X25-V :: 4x 1TB RAID-5 :: 2x 1TB RAID-1 :: 4x 1.5TB :: 1x 2TB
G15v2 :: MX-518 :: Xonar DX :: 7 Pro x64
2408WFP :: DT770/80 :: Onkyo TX-SR605 :: Klipsch RB-61 :: SVS PB10-NSD
Old March 18, 2008, 08:38 PM
Cardboard box with DSL's Avatar
What do you guys think about the Ultimate 360 wc kit from NCIX?
It seems to be everything that I could ever want/need.
Old March 18, 2008, 08:52 PM
Cptn Vortex's Avatar
Yup, that's a killer kit.
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old March 18, 2008, 09:05 PM
Or this:
Pts Petra PT_NUKE Concentrated Biocide Water Additive for Water COOLING(10ML)
In Stock 25454 $4.99 $4.99
Swiftech APOGEE GT S478/LGA775/S754/S940/S939/AM2 3/8IN & 1/2IN &1/4IN Barbs This product cannot be exchanged. Final sale only. No returns or refunds.
In Stock 22287 $44.99 $44.99
Swiftech MCR320 Quiet Power Water Cooling Radiator Black G1/4 Threaded This product cannot be exchanged. Final sale only. No returns or refunds.
In Stock 20090 $64.99 $64.99
Primochill PC Ice NON-CONDUCTIVE Water Replacement 32OZ - Invisible Blue This product cannot be exchanged. Final sale only. No returns or refunds.
In Stock 28632 $7.99 $7.99 1 x Primochill Invisible Blue Dye Bomb Water Additive for PC Ice PC Pure Utopia or Water 1 x Primochill PC Ice NON-CONDUCTIVE Water Replacement 32OZ - Clear
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs This product cannot be exchanged. Final sale only. No returns or refunds.
In Stock 19862 $69.99 $69.99
Masterkleer Pvc Tubing 7/16IN ID 5/9IN OD 10 Feet This product cannot be exchanged. Final sale only. No returns or refunds.
In Stock 21318 $5.99 $5.99
Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings This product cannot be exchanged. Final sale only. No returns or refunds.
In Stock 20091 $19.99 $19.99
D-TEK Customs 1/2IN G1/4 Chrome High Flow Barb Fittings (Pair) This product cannot be exchanged. Final sale only. No returns or refunds.
In Stock 24355 $5.99 $5.99
YOUR TOTAL
$224.92
Old March 18, 2008, 09:14 PM
Oh! I'll be using my current noctua NF-P12s for fans on the rad, high static pressure = fun?
Old March 19, 2008, 03:26 AM
sswilson's Avatar
Looks great, although I'm not sure if the coolant needs a biocide.... Miso????????? :)
Old March 19, 2008, 08:52 AM
On second thought, it seems like everyone and their dog has water cooled the TJ07, and I kind of want to be a little different...
My runner up was the Tagan A+ Black Pearl
If you look at this picture you can see that there is room for an rad internally or externally. My idea is to grab a couple of radboxes and through my MCR320 on the top externally and mounting the pump and res somewhere in the the lower 5.25" bays.
The only part that may require a little moding are the holes for the tubing on the top of the case, i may need to take a drill to them to make them wider. Its that or I could open a pci slot and send my tubing in through there...
Think this will work?
Old March 19, 2008, 09:24 AM
3.0charlie's Avatar
That Tagan reminds me of something... yeah, it reminds me of my Lian-Li PC-V1000. Same brushed Alu., same pull tab to unlock the side panel, same inverted board design, same stealth CD drive cover, same HDD cage design, same front fan attachment, same filter design... jeez. A big brother.
Hydro-Quebec is salivating...
Last edited by 3.0charlie; March 19, 2008 at 09:28 AM. Reason: more of the "same" added...
  #19 (permalink)
Old March 19, 2008, 09:37 AM
Its a direct copy of a Lian-Li case with no really significant changes, but for $215, you cant go wrong on a case that size!
I think I'll do a few mods to the top of the case to fit my rad, I'll drill the holes to make them wide enough for the tubing (and add rubber washers to keep it looking nice) and make a mounting bracket to keep the top of my case happy.
  #20 (permalink)
Old March 19, 2008, 09:46 AM
3.0charlie's Avatar
It is? How can they do that?
The top holes are made for 1/2 tubing, you should be fine as is.
