Old February 7, 2012, 12:42 PM
Default H60 fan screws
Hi guys..
so I got the H60 in silverstone TJ08-e in a pull only config
I want to add a second for a push-pull..
does anybody know what size screws I need to install the second fan?
-joe
Old February 7, 2012, 12:58 PM
Silent_Avenger's Avatar
If it's the same as the H100 as I assume it would be you'll be looking for #6-32 x 1 1/4" machine screws if you're using standard fans. Of course you'll need longer screws if you are running thicker than usual fans and shorter for thinner fans.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old February 7, 2012, 01:01 PM
dandelioneater's Avatar
Corsair has the screw length on their website in the cooling faq section
The screw thread and length are 6 x 32 x 1 1/4"
#6 machine thread, 32 TPI (threads per inch), 1.25 inches in length.
http://en.wikipedia.org/wiki/Screw#U...hread_Standard
Old February 8, 2012, 02:57 AM
Thanks guys!
I guess the next question would be, is there enough room to mount a second in push-pull on the h60?
-joe
Old February 8, 2012, 02:48 PM
techman95's Avatar
yep plenty of room to mount two fans. the rad is the same thickness as the h100 and you can easily do a push pull on that.
Amd....definitely a blond female.....not much on the cpu side, but always strutting about showing off her gpus
Old February 9, 2012, 02:55 AM
mounted the second fan.. ended up jacking two screws from the back fan and installing them on the front fan
temps at 100% drop by 5-8c and returns to idle temp much faster
-joe
Old February 9, 2012, 03:04 AM
supaflyx3's Avatar
It seems i may be a little late, but what i did with my H50 in push pull is use 2 screws on each fan so i didn't have to get more screws.
Old February 9, 2012, 05:45 AM
yeah, that's what I did.. but when I have time I will get more screws just in case..
wonder if home depot or crappy tire have these screws?
-joe
Old February 19, 2012, 12:49 AM
Is there a significant improvment by adding the second fan?
Old February 19, 2012, 01:45 AM
Pabz0r545's Avatar
Wow that is quite the temp difference. When I had a push pull on mine it only dropped by 1 or 2 degrees.
Home depot does in fact sell them but they only offer the silver ones last time I checked. :(
Crappy tire should carry them too.
GPU Screws xilocient Video Cards 8 February 2, 2012 09:03 AM
Rad screws? Birk Water Cooling 13 January 8, 2012 09:07 PM
M4 screws SugarJ Water Cooling 10 December 5, 2011 06:14 AM
[WTB] Stock HS w/screws for 8800GT/GTS , or Just Screws! Soultribunal Buy/Sell & Trade 15 October 29, 2009 01:48 PM
help with screws phantom_jo Off Topic 9 May 7, 2009 09:41 AM
