-   -   Need some help (http://www.hardwarecanucks.com/forum/water-cooling/51367-need-some-help.html)
canada2005 February 7, 2012 09:24 AM
Need some help
Hello, I need some help with a female to female fitting for a Koolance VL3N-FG (quick disconnect) to a bitspower compression fitting with G1/4" thread. Also need one for the male side of the quick disconnect. Not sure what adapter will work and I am using all silver fittings. First time watercooling and I guess all the fittings sizes is messing with my brain.
Footman February 7, 2012 03:57 PM
See what Performance PC has in stock...
