-   -   Looking for a compact D5 res top. This any good? (http://www.hardwarecanucks.com/forum/water-cooling/51218-looking-compact-d5-res-top-any-good.html)
Linus February 2, 2012 06:16 PM
XSPC Acrylic Tank Reservoir for Laing D5
Anyone heard anything about this?
zsamz_ February 2, 2012 06:22 PM
i wish i bought 1 long ago lol
wish dazmode had em @ that price
Linus February 3, 2012 12:30 PM
Well I guess I'll be the guinea pig and just bite the bullet on one.
zoob February 3, 2012 01:00 PM
The design looks similar to the one for the DDC pumps.
It's going to be a PITA to bleed, since the barrel running to the pump inlet will channel the bubbles directly through.
You will need to make an aluminum "spoon" thing to divert the bubbles to speed up the bleeding. Stick it through the top fill-port and manouver it to between the pump inlet and the end of the barrel.
AmuseMe February 3, 2012 05:07 PM
Why the hell would he want to use aluminium?
jtf2 February 3, 2012 05:28 PM
geez if that was an ek product,eddy would have conducted tests and his findings would be that they recommend only to use an ek approved aluminum spoon,to prevent corrosion:rofl:
Dazmode February 3, 2012 06:57 PM
This is not too popular. I would definitely use Vario D5 with this to help with bleeding.
If you are looking for compact, why not DDC?
zoob February 3, 2012 07:01 PM
I never said leave in the aluminum. It's just something that's thin and malleable that you can shape into a U channel to catch the air bubbles. Simply having the spoon in to help bleeding isn't going to instantaneously corrode your rad and blocks.
EDIT: Do like this: XSPC Res Top bleeding made easy
http://www.abload.de/img/xspcres20ak7.jpg
