-   -   Monsoon compression fittings (http://www.hardwarecanucks.com/forum/water-cooling/51096-monsoon-compression-fittings.html)
Keywork January 30, 2012 12:27 PM
Link:
Monsoon Free Center Compression Fittings, 1/2" x 3/4" Six Pack - Black Chrome Products Model: MON-FC-1234-6-BC [MON-FC-1234-6-BC] : Performance-PCs.com, ... sleeve it and they will come
Has anybody had a chance to see or use these yet? Look pretty solid and ~$38 bucks for 6 isn't tooooo bad compared to other offerings.
JD January 30, 2012 01:26 PM
Just saw these today on P-PC's as well.
I don't think they'll be all that useful in a tight situation though where you can't fit the huge wrench into. Although it hurts your thumbs, the "normal" compressions work much better in tight areas where your fingers can only fit into.
Interesting product none the less though!
SugarJ January 30, 2012 02:11 PM
Very nice! I like the look of these.
FlyZ January 30, 2012 02:18 PM
These look good but they need 90s and 45s. Would kinda ruin the look if you were to use other brands.
I still prefer using barbs though.
Prolab January 30, 2012 07:05 PM
That is pretty innovative.
One thing i would add to that, is have the side of the compression nut textured so it can help you grip the nut when its inside a tight place.
bigFOIG January 30, 2012 08:07 PM
It's sort of similar to the XSPC fittings, where there are grooves for you to use a coin to tighten them.
Footman February 7, 2012 03:45 PM
I love these, I have 8 x black chrome on my 3/4OD tubing and they are by far the easiest compression fittings I have ever used. Helps that they look awesome too. I will take some photos once I have moved my kit to my new Trooper case....
SlickEnuf4U February 7, 2012 10:21 PM
I don't like them. I guess I'm just old fashioned. Love barbs or more "classic" style compressions.
Dazmode February 11, 2012 11:40 AM
I really don't like what I see posted on FrozenCPU as extra pictures (installed) and would not personally switch from Bitspower, but if enough people want those we can bring some in.
AmuseMe February 11, 2012 12:08 PM
Bitspower for life! Atkeast someone else us trying something new in terms of design.
