Old January 24, 2012, 07:59 PM
mchutch's Avatar
Default Advice
have water cooling now, but expanding. Ordered some parts and would like some suggestions for the new loop.
I have:
1x CPU block
1x GPU block
1x Motherboard block
2x 120.2 Rads
1x dual 5.25 bay pump/res combo
All 3/8 fittings and tubing.
Suggestions welcome, maybe I am missing something important, very new to water cooling. Using distilled water.
Old January 24, 2012, 08:35 PM
Zer0's Avatar
Silver killcoil or additives to prevent algae growth.
Old January 24, 2012, 08:41 PM
bigFOIG's Avatar
The eyecandy.
Old January 24, 2012, 10:41 PM
Just curious, why did you go for 3/8" and not 1/2"?
Old January 25, 2012, 07:11 AM
AmuseMe's Avatar
Maybe 3/8 x 5/8 over 1/2 barbs? Thats my preferred method. Just spent $600 on Bitspower fittings.... Barbs are a lot cheaper.
Old January 25, 2012, 08:46 AM
lowfat's Avatar
1/2" provides no benefit. Actually 3/8" is better due to its bend radius.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 25, 2012, 09:25 AM
goldry's Avatar
I think 7/16" - 5/8" is also good.
Old January 26, 2012, 10:49 AM
mchutch's Avatar
well thanks guys but was looking for looo advice lol. Is it better to split the loop to each rad then to the water blocks or rad block rad block ect..
Also I like my fitting and tubing size for bend but also it doesn't engulf the whole case, I can still see in there lol
Old January 26, 2012, 10:51 AM
Birk's Avatar
This is what I use and you can get a nice tight system with it, bends like a dream but keeps good flow
Old January 26, 2012, 11:14 AM
Do you need clamps of any sort if you fit that over 1/2 inch barb?
Need some advice HiTi New Builds 4 January 9, 2011 03:45 PM
Fan advice Mavvens Water Cooling 14 October 18, 2010 04:03 PM
PSU Advice Soultribunal Power Supplies 27 December 14, 2009 03:38 PM
Need a little advice here? norfolk Troubleshooting 10 December 14, 2008 12:32 PM
HDD Advice Rommel Storage 3 April 23, 2008 01:34 PM
