Old January 26, 2012, 11:22 AM
lowfat's Avatar
Originally Posted by geoc View Post
Do you need clamps of any sort if you fit that over 1/2 inch barb?
I'd likely use clamps for your first few builds until you get the hang of things. But I have haven't used clamps in at least a good 5-6 years now. 3/8" tubing + non-stubby 3/8" fittings. They are actually more secure then compressions.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 26, 2012, 11:35 AM
non-stubby fittings? Does it matter if they're standard barbs or fat boys?
Old January 26, 2012, 04:09 PM
mchutch's Avatar
do you guys all use teflon tape?
Old January 26, 2012, 04:17 PM
mchutch's Avatar
and again I need loop advice..
Pump/Res>Rad>CPU>Mobo>Rad>GPU>Pump/Res?
or
Pump/Res>Y connect> Rad+Rad>Y Connect>All Blocks>Pump/Res?
Old January 27, 2012, 06:25 PM
mchutch's Avatar
well going to build after work, thanks anyways...
Need some advice HiTi New Builds 4 January 9, 2011 03:45 PM
Fan advice Mavvens Water Cooling 14 October 18, 2010 04:03 PM
PSU Advice Soultribunal Power Supplies 27 December 14, 2009 03:38 PM
Need a little advice here? norfolk Troubleshooting 10 December 14, 2008 12:32 PM
HDD Advice Rommel Storage 3 April 23, 2008 01:34 PM
