  #21 (permalink)
Old March 15, 2008, 06:27 PM
sswilson's Avatar
Originally Posted by e_1337 View Post
ARGH! It's not available!!!!! Damn it. :(
I wouldn't be too concerned about that... it's a kit they throw together themselves from available parts. PM Misoprostol from here and he'll be able to let you know for sure about availability.
  #22 (permalink)
Old March 15, 2008, 06:33 PM
magictorch's Avatar
[quote=e_1337;46288]With my 900 case I have like 6 extra 120mm fans I could use! lol
But I went to NCIX and found these;
Swiftech MCB-120 Radbox Revision 2 Black In Stock 19860 $19.99 $19.99
Swiftech 1/2IN Od Chrome Plated Fittings 1/4 Bspp (Set of Two) In Stock 22451 $5.20 $5.20
Swiftech 7/16IN ID Vinyl Tubing 10 Feet In Stock 19864 $9.79 $9.79
Swiftech APOGEE GT S478/LGA775/S754/S940/S939/AM2 3/8IN & 1/2IN &1/4IN Barbs In Stock 22287 $44.99 $44.99
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs In Stock 19862 $74.99 $74.99
Swiftech MCR220-QP-RES Quiet Power Dual 120MM Water Cooling Radiator & Integrated Reservoir G1/4 In Stock 25909 $57.99 $57.99
TOTAL = $212.95
The radbox is good for mounting to the back of the case. You've got the same parts I just ordered this week (see vortex solution). If you NCIX price match using DC prices this will go down to $185 or so plus I bought some swiftech uv reactive biocide/cleaner for $2.50 or so. You could always buy from DC directly too..the DC rep here takes care of things very well.
  #23 (permalink)
Old March 15, 2008, 06:46 PM
[quote=magictorch;46305]
TOTAL = $212.95
I forgot about pricematch! lol My total is about $195
Intel Core 2 Quad Q6600 "G0" 2.4GHz Overclocked @ 3.6GHz (1.48v)
Thermaltake Big Water 760is (Custom Coolant)
Antec TruePower Quattro 1000watt (Modular)
Asus Maximus Formula BIOS v1004
8GB OCZ PC2-6400 800MHz Vista Performance Platinum Edition @ 5-5-5-15 2T
Sapphire Radeon 3870x2 || Diamond Radeon 3870x2
WD Raptor 74GB 10,000rpm SATA | WD 500GB 7200rpm SATA | WD 500GB 7200rpm SATA
LG DVD-RW Dual Layer SATA
Thermaltake Armor 8003 (Modded)
http://www.heatware.com/eval.php?id=63819
In search of a silent solution CMetaphor Water Cooling 13 February 13, 2008 07:51 PM
Cooling Solution for Pentium D 3.6 wpurcell Water Cooling 7 July 11, 2007 09:30 AM
