Old March 15, 2008, 05:29 PM
Originally Posted by sswilson View Post
The only things wrong with that build are the lack of fans, and the inclusion of two rads... :)
I'd also suggest a radbox for the easiest installation.
With my 900 case I have like 6 extra 120mm fans I could use! lol
But I went to NCIX and found these;
Swiftech MCB-120 Radbox Revision 2 Black In Stock 19860 $19.99 $19.99
Swiftech 1/2IN Od Chrome Plated Fittings 1/4 Bspp (Set of Two) In Stock 22451 $5.20 $5.20
Swiftech 7/16IN ID Vinyl Tubing 10 Feet In Stock 19864 $9.79 $9.79
Swiftech APOGEE GT S478/LGA775/S754/S940/S939/AM2 3/8IN & 1/2IN &1/4IN Barbs In Stock 22287 $44.99 $44.99
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs In Stock 19862 $74.99 $74.99
Swiftech MCR220-QP-RES Quiet Power Dual 120MM Water Cooling Radiator & Integrated Reservoir G1/4 In Stock 25909 $57.99 $57.99
TOTAL = $212.95
The total is cheaper, what should I add to complete the set-up? What biocide/coolant etc should I use? I was going to use the coils for the cool blue effect, but It might be easier to add food colouring? I want blue for sure. :) Thanks.
P.S. Do I really need the radbox?? I can place the thing on the top of my new case? It's huge! lol
Intel Core 2 Quad Q6600 "G0" 2.4GHz Overclocked @ 3.6GHz (1.48v)
Thermaltake Big Water 760is (Custom Coolant)
Antec TruePower Quattro 1000watt (Modular)
Asus Maximus Formula BIOS v1004
8GB OCZ PC2-6400 800MHz Vista Performance Platinum Edition @ 5-5-5-15 2T
Sapphire Radeon 3870x2 || Diamond Radeon 3870x2
WD Raptor 74GB 10,000rpm SATA | WD 500GB 7200rpm SATA | WD 500GB 7200rpm SATA
LG DVD-RW Dual Layer SATA
Thermaltake Armor 8003 (Modded)
http://www.heatware.com/eval.php?id=63819
Old March 15, 2008, 05:50 PM
sswilson's Avatar
Check out HWC's sponsored deals (NCIX) here.... http://www.hardwarecanucks.com/forum...html#post46112
You'll save $5 on the pump, and depending on what folks think of Masterkleer tubing (I haven't used it so I can't comment) you can save another $4 on that as well.
You're still missing fans. I'd suggest Yate Loons just for the amazing price on them, but I'm sure others will suggest slightly pricier ones for better performance.
Old March 15, 2008, 05:52 PM
120mm fans correct? I have 6 extra from my 900 case, can't I use them?? What about the biocide and coolant etc, I'm ordering tonight. :)
Old March 15, 2008, 06:05 PM
sswilson's Avatar
There's the coolant on sale as well, but I'm not sure if it includes a biocide, and I'm not sure how well it works compared to straight distilled water.
If it were me.... I'd pick up some petra's biocide and the blue dye bomb you listed earlier to go with distilled water.
As far as the fans go.... you can use your current fans, but don't you need them to cool your case? It's important for water cooling rigs to keep case airflow going as you lose the cooling effects of the cpu cooler on motherboard components.
Old March 15, 2008, 06:13 PM
The fans are from my old 900, I'm grabbing the Thermaltake Armor case, so the I can use all the fans from the 900. :)
Old March 15, 2008, 06:18 PM
sswilson's Avatar
Have you compared pricing using this.... http://www.ncix.com/products/product...er=1&sku=26522 ?
Throw in a radbox and you've got essentially the same setup with a couple of fans for it. The only difference is the use of a res (X-tra viewing coolness inside the case... :) ) rather than the rad with a built-in res.
Old March 15, 2008, 06:19 PM
sswilson's Avatar
Oh, and don't forget to throw in some thermal compound if you don't have some kicking around the house... :)
Old March 15, 2008, 06:20 PM
Wow, that's almost 30 bucks cheaper!! I think I'll go with that and some biocide and dye! What do you think? Is that a good system??
  #19 (permalink)
Old March 15, 2008, 06:24 PM
ARGH! It's not available!!!!! Damn it. :(
  #20 (permalink)
sswilson's Avatar
Yeah, you won't have any compaints about this as a first WC cooling system.
Higher end components can be bought (better rad, slightly better water block), but that would start pushing your loop closer to the $400 range for marginal gains (those extra 5c cooling that are important to the true WC enthusiasts... :) ).
In search of a silent solution CMetaphor Water Cooling 13 February 13, 2008 08:51 PM
Cooling Solution for Pentium D 3.6 wpurcell Water Cooling 7 July 11, 2007 09:30 AM
