-   -   (Updated) Sigh, I have great luck with CPU blocks... (http://www.hardwarecanucks.com/forum/water-cooling/50690-updated-sigh-i-have-great-luck-cpu-blocks.html)
matari January 19, 2012 08:04 PM
See my last post for update
Why me...
http://img.tapatalk.com/4722b4c9-cd86-5ef1.jpg
AmuseMe January 19, 2012 08:06 PM
Is that a brand new block, that you just peeled the sticker off of?
BT! January 19, 2012 08:12 PM
try getting some 2000 - 2500 grit automotive sandpaper and use the lapping process to clean it up, might work.
matari January 19, 2012 08:49 PM
Brand new; got it Tuesday.
matari January 19, 2012 08:57 PM
Sent a couPle RMA request, I will see what happens.
goldry January 19, 2012 10:44 PM
Originally Posted by matari (Post 592513)
I hade the same problem. You can easily clean it.
1) Mix flour and vinegar
2) Apply on the CPU block
3) Wait for 10 minutes (maybe more)
4) Rinse with water
It will look like new :thumb:
JD January 19, 2012 11:58 PM
4) Rinse with water
I believe Ketchup may also work?
I don't think a RMA will do you much good. Copper oxidizes, it's fact.
Supergrover January 20, 2012 12:13 AM
Yeah ketchup works also, as does elbow grease or a dab of IC7.:whistle:
I have used the vinegar and salt years ago.
Linus January 20, 2012 02:43 AM
brasso works wonders. Then I clean off the residue with soap & water.
Footman January 20, 2012 07:25 AM
Pretty normal oxidization, use some ketchup. it will not affect performance one bit.....
