Originally Posted by BobbyLou If you use uncoated blocks like this it something that just comes with the pudding.
No need to RMA. I'd recommend nickel coating if you don't want it to oxidize. |
I did not RMA, just wanted to know what to clean it with without voiding warranty. Correct packing should prevent this issue. My argument is no one should have to receive a block in this condtion, or should have to give the block an acid bath. I realize the issue does not affect performance, but my OCD just can't take block that looks like someone took a dump on it. On a good note, AC is aware of the issue and will change the way they package the product.
