Old January 16, 2012, 03:39 PM
Originally Posted by lowfat View Post
Why are those your only choices?
They seen to have the best bang for buck ratio. Only 1 or 2C difference from their big brothers, and cost half.
Old January 16, 2012, 05:04 PM
lowfat's Avatar
Where are you buying from?
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 16, 2012, 06:08 PM
aquatuning.us, 6 dollar 72hr shipping! :D
Old January 16, 2012, 09:42 PM
matari's Avatar
I never bought a low cost version. The original with the plastic top is normal only 10 15 USD more the the LC versions.
Old January 16, 2012, 09:49 PM
KaptCrunch's Avatar
Originally Posted by zoob View Post
Lot of complaints over @ xtremesystems about the HK turning black:
Why I hate my HeatKiller Rev 3.0...
for user over dosing Ptnuke, only when exposed turns black like that pic tells me used acetic acid (vinegar). wipe some vinegar on any copper an see for self and match that pic
Old January 16, 2012, 10:09 PM
yea, but it offers at most 1C in temperate difference
Old January 21, 2012, 01:46 PM
lowfat's Avatar
How about Aquacomputer?
Aquatuning -Your watercooling and modding distributor - Aquacomputer cuplex kryos Delrin for sockets 1366/1156/1155/775, G1/4 10372
Queen of Dreams WIP
Big Lian Li
Complete
Old January 21, 2012, 03:30 PM
How do they fare compared to HK 3.0? I'm about to hit the check out button soon (once I figured that I have gotten everything i needed)
EDIT: nvm, I can't fit the block into my PC, the clearance of the top radiator prevents me from putting a fitting/tubing to the top half a 1366 block.
  #19 (permalink)
Old January 21, 2012, 04:07 PM
matari's Avatar
Unhappy
The AC HF is thermal the best performing block out there. The Derlin version has no backplate; it's mounted to the board. The block's back plate will more than likely come oxidized. They use dont Lacquer, and they probably been in storage for some time.
GTX 580 or Watercool my 480? Goalieman077 Video Cards 4 June 28, 2011 08:12 AM
what do I need to watercool my gtx285 Shadowmeph Video Cards 9 June 29, 2010 04:21 PM
[Review] Blowing dust from good ol' Supreme and Supreme LT Dazmode Water Cooling 0 May 5, 2010 05:01 PM
First Watercool - Advice? LegendofJubei Water Cooling 6 September 8, 2008 07:25 PM
What Watercool kiy to buy jasonmoreau Water Cooling 6 February 11, 2008 11:25 AM
