Old January 15, 2012, 09:08 AM
Default controlling temperatures for watercooling
I finished doing my build and now it is time to start my watercooling setup
I need to watercoold my i7 2600k and EVGA GTX 580
I will need suggestions on parts to buy
I have a Corsair 400r case, so I could mount a SLIM dual rad on the top and a single 120 rad in the back
Which waterblocks do you recommend?
Which rads, rez and pump?
As for the fans, do I need a fan controller or can I use the onboard fan headers on my ASUS P8Z68-v board?
Old January 15, 2012, 09:13 AM
To watercool the 580 you will need a good beefy rad. Those things dump huge amounts of heat. May need to rethink your strategy.
Old January 15, 2012, 09:34 AM
water doesn't necessarily cool better, it carries the heat away to somewhere with ideally more surface area.
If you think you can get more cooling surface area with a slim rad in a small case you could try it.
Old January 15, 2012, 10:00 AM
KaptCrunch's Avatar
H100 for gpu H80 for kit cpu since is corsair with no fussing with fluids
yes good to use a fan controler if sensitive to sound
Old January 15, 2012, 10:01 AM
How much surface area does the 580 heatsink have compared to a dual 120 slim rad and a single 120 rad?
Old January 15, 2012, 10:02 AM
can't you configure fan speed profiles with the p8z68-v board in the AI suite?
Old January 15, 2012, 10:24 AM
KaptCrunch's Avatar
yes for case but rad fans would rather do manual speed adjustment
Old January 15, 2012, 10:50 AM
a35599's Avatar
I have used this website for ages to design my water cooling systems, as well as load calculations for PSU.
eXtreme Flow Designer
Filtering & Controlling Home Network MrDiaz Networking 11 May 18, 2011 04:34 AM
Temperatures on an x2 555 poroporo Overclocking, Tweaking and Benchmarking 3 May 14, 2010 07:27 PM
Asus M3a79-t controlling fans Jonwall Air Cooling 0 March 27, 2009 04:20 PM
Motherboard fan controlling? chibi_man Troubleshooting 7 July 15, 2008 09:52 PM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
