-   -   CPU running way too hot (http://www.hardwarecanucks.com/forum/water-cooling/50477-cpu-running-way-too-hot.html)
guster11 January 14, 2012 07:21 PM
I recently installed an xspc rasa 750 rs360 kit on my i7 2600k, and after a becnhmark at only 4.6 Ghz today, it hit 95 degrees celsius. I mean, the only thing i can think that is causing the problem is the lack of a backplate, due to the fact it wouldn't even come closing to lining up with my maximus IV motherboard. Any help or ideas are really appreciated, thanks!
Supergrover January 14, 2012 07:35 PM
Could be air in the loop or a bad mount. Did you leaktest the bubbles out? if so I would say remount the block and try again.
lowfat January 14, 2012 08:44 PM
If you aren't using the backplate there is a good chance you have a poor mount on the waterblock. Have you tried making the cuts needed to get the backplate to work?
guster11 January 14, 2012 08:51 PM
There was no way to modify the backplate to fit other than use the screw parts as serperate pieces, which i did do. Are there any other mounting brakets that work with the rasa 750?
Yeah, there is no air in it, I leaktested the crap out of the loop. Thanks for the advice!
jibz January 14, 2012 09:09 PM
sounds like the CPU block isn't mounted at all if just barely. Or the pump isn't working?
Birk January 14, 2012 09:15 PM
my guess is no backplate is leaving too much space in the mount.
guster11 January 14, 2012 09:31 PM
Kinda what I've been thinking, but is there any backplates that are compatible with the block? I need a new one kinda.
edit: actually i'll try the lga 2011 fix kit. Thanks for the help guys!
Oh one more questions as a water cooling noob, when I swap the mounting screws, should i drain the loop?
KaptCrunch January 14, 2012 09:59 PM
unless you think something in loop, should be ok just be careful of hoses not to pop off for i can't see what/feel using for clamps
C0llateralDamag3 January 23, 2012 08:42 AM
Air in Loop
Stupid question for a new builder - how do you get the air out of the loop? I definitely have bubbles and I'm pretty sure that's why my temps run higher then they should.
Currently idles around 31c and under prime95 66c. Not horrible but should be better -
I have a RX360 in a push/pull setup.
thoughts?
jibz January 23, 2012 08:58 AM
It seems awkward but to help bleed your systems you need to lean your case over in all directions and give it a little shake to try to get trapped air out from all the little pockets, especially if you have a top mounted radiator you may want to flip your case upside down for a second.
