Old January 13, 2012, 11:11 PM
Birk's Avatar
Default Just setup my first Custom Loop
Here it is, its leak testing right now
I'm pretty happy with how tight and tidy I was able to get the tubing.
Anything anyone can see I shoudl Correct?
Right now it runs in this order.
Rez -> Rad -> CPU -> GPU -> Rez
Old January 14, 2012, 06:05 AM
Babrbarossa's Avatar
Very nice - nothing wrong with that loop.
psst, wanna see my binder?
Old January 14, 2012, 07:03 AM
sswilson's Avatar
Looks great!!!!
Welcome to the wild and (only if you don't use an algecide of some form) sometimes furry world of watercooling!!!!!!! ;)
Old January 14, 2012, 08:23 AM
Birk's Avatar
I only ordered 6 feet of the UV Blue tube, i had read you should have at least 8-10 feet of tube. I only used like 4.5 feet including 1 wrong cut (that i used as a filler tube). It all went without a hitch and has been leak testing for 9 hours, im off to work so it'll be close to 20 hours leak tested before I'm home and ready to setup again. Not a drip so far!
-- Main System --
THERMALTAKE Chaser MK-1
ASUS P8Z68-V Pro / Gen3
INTEL Core i5 2500K @ 4.5ghz 1.35v
- XSPC Raystorm
DIAMOND Radeon HD 6950 2gb @ 840/1325
- AQUACOMPUTER AquagrATIx Full cover Block
CORSAIR Vengeance C9 16gb (4x4) 9.9.9.24
OCZ ZX 850w Gold
WD 320gb, 1Tb, 500gb
LG 22x Super Multi DVD
Old January 14, 2012, 01:00 PM
Silent_Avenger's Avatar
I think the 8-10 feet estimate is for covering those running like 3 rads and would have to have a ton of tubing. It does look nice and clean great work. Can't wait until I save up enough for my own loop now. :)
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old January 15, 2012, 12:05 PM
Nice loop man. Looks similar to mine. Only thing you might consider doing the next time you put it together is adding a drain port off the bottom of the vid card.
My stuff for sale.
Mah Rig
Old January 15, 2012, 12:48 PM
Birk's Avatar
yea for sure, i forgot to pick up a proper end to do it with :( but that is 100% going to be in my next loop. I also plan to do away with the dual bay rez/pump combo and get a tube rez and put my D5 back on its stand.
-- Main System --
- XSPC Raystorm
OCZ ZX 850w Gold
Old January 15, 2012, 01:54 PM
a35599's Avatar
Looks good. I agree with the drainport, you will find it very nice to have when it comes to maintenance. A good site to design water cooling loops, very useful : eXtreme Flow Designer
Old January 15, 2012, 05:15 PM
Keywork's Avatar
Looks good. How are temps with just the single 240 rad?
Old January 15, 2012, 06:22 PM
Birk's Avatar
@ 4.5ghz with 1.35vcore i'm at ~30 idle and ~60 max load
-- Main System --
- XSPC Raystorm
OCZ ZX 850w Gold
Deciding on a new Case & Custom Loop siegfx Water Cooling 16 January 3, 2012 10:37 AM
Getting new GPU blocks, Custom loop recommendation needed! siegfx Water Cooling 7 December 17, 2011 04:53 PM
custom or closed loop? help me decide which one is right for me. Pabz0r545 Water Cooling 15 November 3, 2011 04:45 PM
Custom watercooling setup Night Gyr Water Cooling 12 December 31, 2010 11:21 AM
120.1 Custom Loop vs Corsair H70 PriceMatch Water Cooling 16 December 26, 2010 05:31 PM
