Old January 11, 2012, 10:07 PM
Default Tee connector before pump inlet
Hi Everyone!
Newbie to WC and starting on my first loop. Planning to put in a drain line and the lowest part of my loop is the d5 vario pump. I'm thinking if it's a bad idea to put in a "tee" connector (the plastic kind you buy from home depot) just before the pump inlet? would this cause cavitation? I've seen some rigs with Tees before the inlet but they were used as T-line or fill ports.
Im itching to get started and would like to clear this up first. Thanks!
Old January 11, 2012, 11:56 PM
Prolab's Avatar
Only time you use a "T" is if your not planning on using a reservoir. Its makes filling and bleeding the loop easy.
But if your planning on using a reservoir, there's no point in using a "T" line since you'll be using the res to fill the loop.
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
Old January 12, 2012, 12:19 AM
apologies, i was'nt clear.
I already have a res. the T connector was for a drain line. i was hoping for res>T connector from there the line splits to the inlet of the pump and the other line to a drain port. My concern is that since it's a drain port, it's at level with the pump. would this cause cavitation? again the pump is the lowest in my loop that is why i thought if it's possible to put it there.
Thanks!
Old January 12, 2012, 02:23 AM
I never had any issues using a t coupler for a drain port. I put mine just before the resi and not after the pump. So it was closer to the end of the loop before the pump and not directly after. If you are using 1/2" ID tubing you can always use a brass fitting too. Couple bux at any hardware store.
Mah Rig now
Mah Rig before
My stuff for sale.
Old January 12, 2012, 07:01 AM
Thanks!
4+4 pin CPU connector vs 8 pin ATX connector sstrucel CPU's and Motherboards 1 August 5, 2011 07:45 AM
Which connector do I need? Fudd Rucker Water Cooling 13 January 25, 2011 09:18 AM
[WTB] Need a wc'ing sli connector G777 Buy/Sell & Trade 6 November 24, 2010 06:02 PM
Anyone seen a 3>1 fan connector around? Jmark Water Cooling 5 October 19, 2009 03:33 PM
8 Pin 12V ATX Connector element291 Power Supplies 6 August 24, 2009 08:52 PM
