Old January 11, 2012, 09:17 PM
r0k0's Avatar
Default Water Additive
Hey guys... i'll be adding a GPU WB soon so i'll be changing all my tubing soon at the same time
now i have Thermaltake Water Coolant the Green stuff... but i'd like just plain White or another color than green so i found this
DazMode Protector Dazmode Protector [DAZMODE PROTECTOR] - $6.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
so i mix that with just the normal distilled water we buy at Canadian tire and im good for cooling my pc ?
Intel i7 3930K / 16GB Corsair Vengence DDR3-2400
Asus X79 Rampage Extreme Black Edition / EVGA GTX 770
Corsair 480GB SSD / 1TB WD Black
IN WIN 303 / EVGA NEX750 Gold
Old January 11, 2012, 09:20 PM
JD JD is offline
Yup, just mix it with 2L of distilled water and you're set.
Old January 12, 2012, 05:31 AM
r0k0's Avatar
Thanks JD
Is clear liquid easy to see flow ? I can see my green fine, just worried if the pump dies I won't see the clear liquid flow in my resovoir
Old January 12, 2012, 08:10 AM
JD JD is offline
It's definitely more difficult as I was recently running straight distilled (temporarily). However if you hold a flashlight up to it, you can somewhat see things if there's still some bubbles in the loop. I never fully bled it so I'm not sure how it would be without bubbles.
Old January 12, 2012, 11:30 AM
r0k0's Avatar
Which color would you suggest thay fits well with black inside case, white led nzxt kit white fans ?
Old January 12, 2012, 02:59 PM
JD JD is offline
That's a pretty neutral colour scheme you currently have, so any colour would go fine with it IMO. Pick your favourite colour?
Old January 12, 2012, 03:00 PM
Amarthfea's Avatar
I run distilled in my setup, its not too hard to see even with colored tubing. If your burping the system I highly suggest a little 99 cent led flashlight, stick it behind the tubing and let the light shine through the tubing to check for air pockets, I find this very effective.
Also i've never been able to get the microscopic bubbles out so you always see those ones right around the outlet of the pump. And if you have a clear res you will see it bubbling away as well.
~Elysium, I behold your beauty...
Old January 13, 2012, 03:50 AM
r0k0's Avatar
anyone ever use the Feser Black Dye ?
Old January 13, 2012, 12:59 PM
JD JD is offline
I had considered it quite some time ago, but never tried it. From what I remember reading, it was more of a dark purple than a black. Not sure if they've corrected that now or not.
Old January 13, 2012, 02:34 PM
dandelioneater's Avatar
I thought i saw something a while back where people's blocks got all gunked up with that pre-mixed stuff. Personally I've always liked distilled with some swiftech HydrX (NCIX) and never saw any corrosion or gunk with that stuff.
Using prestone as additive? Charloz24 Water Cooling 13 April 7, 2010 05:22 PM
What additive are you using in your water MarkOne Water Cooling 45 March 8, 2010 04:12 PM
Bike won't start after using NOS fuel additive CTA Off Topic 17 May 24, 2009 02:42 PM
Water is the best? magictorch Water Cooling 16 January 25, 2009 06:41 PM
Help With Coolant Additive Johnnyl168 Water Cooling 18 November 29, 2008 05:34 PM
