Old January 11, 2012, 08:51 PM
bigFOIG's Avatar
Default Need suggestions on setting up my WC build
There are some pictures of what I'm doing with my 600T case in this thread.
Corsair 600T SE Watercooled; internal triple radiator mod
This is my first WC build, and I can't decide where I'll be putting the pump and reservoir. I can't decide which side to have the fittings of the radiator on after mounting it. Left side or right side?
Oh decisions....
Old January 11, 2012, 09:21 PM
Personally I would put the radiator connections over the 5.25 bays and the pump and res in the 5.25 bay.
Would hide some tubing and parts if your going for a clean look.
Old January 11, 2012, 09:45 PM
bigFOIG's Avatar
Good. Because it's mounted that way right now, and I didn't want to remount it. It's not easy with the super tight fit against my motherboard.
Do you think I can get it bunched up in there with only straight fittings?
Old January 11, 2012, 11:20 PM
its possible, what parts are you using?
If you can get your hands on a male-male extender and connect the pump and res together that works nicely.
Old January 11, 2012, 11:33 PM
bigFOIG's Avatar
Check out my worklog. Wrote up my WC parts and pictures.
setting up my new build, but have a few questions and concerns obliviousmike New Builds 4 July 29, 2011 02:13 PM
[!] - i5 Build - Need Suggestions - [!] irtehleet New Builds 12 April 27, 2010 05:19 PM
New build, suggestions vintank New Builds 27 January 28, 2010 06:28 PM
Need help setting up the LED's and lights on my BUILD hen555 Troubleshooting 11 December 20, 2009 04:05 PM
Need suggestions on new PC build markmilo1115 New Builds 7 July 14, 2009 10:03 PM
