Old January 11, 2012, 01:07 PM
Shadowmeph's Avatar
Default looking for a fitting to connect to rads together
I an looking for a fitting that will connect the output of one ran into the input of another rad I want it to be wide enough so that a fan can fit a little snug in between the to rads. I have looked around but I haven't seen any actual fitting like this except for the fitting that goes in between two watercooled video cards
Old January 11, 2012, 01:17 PM
A SLI adjustable connector could work, with additional male-female extender if necessary.
Could be a waste though since heat dissipation is heavily influenced by the difference between air and surface temperature. Then again Noctua's NH-D14 seems idiotic from a design perspective as well and it's a god like cooler.
Old January 11, 2012, 01:18 PM
Birk's Avatar
I haven't seen one for that. I'd think you're best bet would be to just hose it as best you can with compression fittings.
Old January 11, 2012, 01:44 PM
Shadowmeph's Avatar
Hmm ok well I might just have to make one then lol
Old January 11, 2012, 01:54 PM
Supergrover's Avatar
What about just using a fitting/spacer/fitting? Plenty of different sized spacers available.
Just need to measure the distance you need minus the fittings you are using and grab the correct sized spacer or 2 spacers added together.
Edit my bad wording they are technically called extenders:)
Reducers & Extenders : Performance-PCs.com, ... sleeve it and they will come
R.I.P.
Old January 11, 2012, 02:34 PM
Exactly, extenders come in all lengths added to an adjustable GPU to GPU it should bridge any gap.
Old January 11, 2012, 03:19 PM
AmuseMe's Avatar
BitsPower 'D' Plug
Bitspower Matte Black G 1/4 D-Plug Set for Direct Connection #BP-MBWP-C07
Old January 11, 2012, 03:56 PM
Ooohh I like that D plug idea for easy installation.
Old January 11, 2012, 08:14 PM
Shadowmeph's Avatar
aww ok I never thought of those
Old January 11, 2012, 08:20 PM
Originally Posted by AmuseMe View Post
Yup I have used those before multiple time and narry a leak and works like a disconnect, drained though obviously.
R.I.P.
mixing rads Raftus Water Cooling 3 December 8, 2012 05:30 AM
D5 w/ EK top + 3 x 360 rads Prolab Water Cooling 6 October 21, 2011 07:14 PM
how many rads can a 655 push through Shadowmeph Water Cooling 40 September 20, 2009 10:08 PM
[WTB] Thermochill rads Frank Booth Buy/Sell & Trade 0 March 20, 2009 06:08 PM
Two Rads? Infiniti Water Cooling 20 June 14, 2008 05:55 PM
