  #31 (permalink)
Old August 19, 2013, 10:25 PM
distilled water will always be the most thermally conductive option for water cooling mix a little glycol in there as a biocide on the cheap. Even a shot glass or 2 will do the trick. The stuff Daz sells is basically glycol... yes it's true I looked into it and bought some to make sure.
Don't waste your money on fancy cooling liquids it's just a gimmick.
Mah Rig now
Mah Rig before
My stuff for sale.
  #32 (permalink)
Old August 20, 2013, 03:57 AM
biff's Avatar
Holy thread resurrection!
But I still agree.... its distilled plus a bit (~10%) for me. I ran one of the "specialty" fluids for a while (fesser IIRC) and it lasted nearly a year before the algae completely plugged the system. Never seen even a hint of algae with glycol. Though it isn't as pretty, depends on your priorities I guess.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
  #33 (permalink)
Old August 20, 2013, 07:57 PM
I used some orange stuff in my last build you can barely see the color in it compared to the green
Mah Rig now
Mah Rig before
My stuff for sale.
Water cooling fluid question tzetsin Overclocking, Tweaking and Benchmarking 47 February 18, 2008 05:13 PM
Watercooling the Antec 900 JD Water Cooling 44 December 10, 2007 09:13 AM
Watercooling GPU's/CPU/kit frosty Water Cooling 55 October 23, 2007 06:19 PM
Internal watercooling kit kING4000 Water Cooling 18 October 15, 2007 11:05 AM
Overclock3D on Fluid XP+ HP watercooling fluid Supergrover Reviews & Articles from the Web 0 January 15, 2007 06:08 PM
