  #21 (permalink)
Old March 15, 2008, 10:39 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Originally Posted by CanadaRox View Post
Anyone have any idea how regular food colouring would work to add some colour too a loop?
That's what I use for color, food coloring and distilled water. No issues at all
  #22 (permalink)
Old March 24, 2008, 11:55 AM
elninio's Avatar
where can i get some very effective biocide in ontario?
  #23 (permalink)
Old March 24, 2008, 12:32 PM
Cardboard box with DSL's Avatar
Iodine from your local drug store....
  #24 (permalink)
Old March 24, 2008, 01:16 PM
biff's Avatar
You can also get Copper Sulphate from the drug store (behind the counter, ask the pharmacist), which is the same stuff that's used in PT Nuke. AFAIK you can only get it in 500g of powdered form which is WAY WAY more than you'll ever need but it's only $5... if questioned just say it's for your swimming pool. This is what I have, however I haven't worked out the mix ratio yet.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
  #25 (permalink)
Old March 24, 2008, 02:28 PM
Cptn Vortex's Avatar
I just ordered some Feser-One Black/UV Blue additive, I'll let you know how that works out for me. http://www.ncix.com/products/index.p...re=Feser%20One
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
  #26 (permalink)
Old April 10, 2008, 01:30 PM
Originally Posted by Eldonko View Post
Ive watercooled for years using only distilled water. Ive had leaks (small ones) a few times but as long as you notice it before it soaks everything when it's on, you are good. Water doesnt kill hardware as easy as people think, I mean if you can bench with your GPU in this condition...
Wow That gives me the chills you were actually able to bench it like that? OMGOZERS
I would not recommend putting food coloring in your loops as it has no performance gains and it will deteriate the coolant faster. And anyways just imgaine this gunk build up with flakky unwanted skin in your tubing in the next couple months =X
Yes please post us a review on that stuff I too would like too add some color UV Lights + UV Liquid =P~ = Looks CoOoL
Intel P4 2.0Ghz @ 3.5Ghz ON AIR! >> FTW?!
Heatware
  #27 (permalink)
Old April 10, 2008, 02:15 PM
Well, it's not as good as it looked on paper.... But I am still happy with the results.
http://www.hardwarecanucks.com/forum...html#post48465
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
  #28 (permalink)
Old September 29, 2008, 11:09 PM
Mulder's Avatar
I apologize for necroing this thread. I've built a lot of WC rigs and only ever had one problem with leaks and sediment in the cooling lines. A friend of mine had me build him a WC rig for his pc and then he put a small amount of plumbing antifreeze in his loop instead of automotive antifreeze. Around three weeks later I recieved a call form him telling me how the plastic barbs/joints on his waterblock eroded and leaked fluid destroying his PC.
  #29 (permalink)
Old August 15, 2013, 04:42 PM
Simpleton's Avatar
Default Coolant
Myself I'm just over 2 years on my Feser One coolant and so far it seems ok except I had to add some twice and it's a lot less UV-reactive now.No way for me to know if it's less effective at cooling since I have upgraded Motherboard and CPU a little while back and the older systems temps can't be used for comparison.If I ever change it I will do a before and after, until then I won't mess with it...
  #30 (permalink)
Old August 15, 2013, 05:32 PM
IRQ Conflict's Avatar
Necro>Monster Epic Necro
Water cooling fluid question tzetsin Overclocking, Tweaking and Benchmarking 47 February 18, 2008 05:13 PM
Watercooling the Antec 900 JD Water Cooling 44 December 10, 2007 09:13 AM
Watercooling GPU's/CPU/kit frosty Water Cooling 55 October 23, 2007 06:19 PM
Internal watercooling kit kING4000 Water Cooling 18 October 15, 2007 11:05 AM
Overclock3D on Fluid XP+ HP watercooling fluid Supergrover Reviews & Articles from the Web 0 January 15, 2007 06:08 PM
