Old March 13, 2008, 08:55 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Ive watercooled for years using only distilled water. Ive had leaks (small ones) a few times but as long as you notice it before it soaks everything when it's on, you are good. Water doesnt kill hardware as easy as people think, I mean if you can bench with your GPU in this condition...
Old March 13, 2008, 09:21 AM
Babrbarossa's Avatar
Originally Posted by Moneyless View Post
(I had highlighter ink in the loop as well for some color but the alcohol has made it fade out... :/)
Old School!
Old March 13, 2008, 10:58 AM
CanadaRox's Avatar
I read a review about a week ago comparing four liquids, and distilled water + water wetter. The distilled water had the best temps overall. Second came Feser One, which was actually non conductive (not like most others which say it, but aren't). The reviewer even splashed it on his motherboard and videocard while it was running just to see, and he wiped it off with no negative effects. FluidXP was actually rated the worst out of them all, and because it was a bit thicker than the rest, it also made the pump run a bit louder. So if you want fancy colours and 100% non-conductiveness (not really a word :() Feser One is the best choice. But if all you want is the lowest possible temperatures, go with distilled water and water wetter.
I'll see if I can find the review again.
Project: Black and White
Old March 14, 2008, 12:23 AM
Moneyless's Avatar
Originally Posted by Babrbarossa View Post
Old School!
"I hate broccoli
And think it totally sucks
Why is it not meat?"
-Deadpool
Old March 14, 2008, 07:41 AM
Misoprostol
Guest
Posts: n/a
Augh! To the people using alcohol and bleach in their loops: CEASE AND DESIST!!
These can break down seals in things like blocks and reservoirs. Switch to something non corrosive TODAY. I recommend water and iodine in low concentration (for purifying drinking water while camping: can be had for $5 at the pharmacy)
Old March 14, 2008, 04:22 PM
magictorch's Avatar
Default good advice
Thanks for the advice. Got some distilled water and Swiftech Hydrx additive Swiftech Hydrx Water Additive Coolant 2 oz Bottle - DirectCanada
waiting for the rest of the stuff in the mail.
think ill post some pics of the build
Eldonko-kind of like the frosted GPU look
Old March 14, 2008, 08:45 PM
Eldonko's Avatar
Yeah me too, it's from joe_cool and no_name when the broke those WR at cebit.
Old March 14, 2008, 10:48 PM
Moneyless's Avatar
Originally Posted by Cptn Vortex View Post
Interesting, highlighter ink. Haha. How long have you had your loop together?
About a month and a half now.
"I hate broccoli
-Deadpool
  #19 (permalink)
Old March 14, 2008, 11:27 PM
CanadaRox's Avatar
Anyone have any idea how regular food colouring would work to add some colour too a loop?
  #20 (permalink)
Old March 15, 2008, 02:19 AM
llama_egg's Avatar
Alot of people seem to use it, so I really don't think it can hurt, though you still should add something to kill stuff that grows and will attack you in your sleep.
Water cooling fluid question tzetsin Overclocking, Tweaking and Benchmarking 47 February 18, 2008 05:13 PM
Watercooling the Antec 900 JD Water Cooling 44 December 10, 2007 09:13 AM
Watercooling GPU's/CPU/kit frosty Water Cooling 55 October 23, 2007 06:19 PM
Internal watercooling kit kING4000 Water Cooling 18 October 15, 2007 11:05 AM
Overclock3D on Fluid XP+ HP watercooling fluid Supergrover Reviews & Articles from the Web 0 January 15, 2007 06:08 PM
