Old January 11, 2012, 09:45 AM
SugarJ's Avatar
Originally Posted by Silent_Avenger View Post
There's no residue on your parts is there? That's the only thing I'm worried about with dyes in the coolant is having coloured residue stuck to everything. Otherwise it looks nice, do they sell the dye separately or premixed? If it comes separately I could probably just keep adding dye until I get the right colour I want.
P.S. is that G.Skill ram hiding under there? the heat sinks look familiar.
I use the premixed. I had a bad experience with a dye separating out one time, and won't go there again. I haven't had buildup on the blocks. It will stain the tubing. So far, I've been able to wipe the plexiglass res and block parts clean, but I won't guarantee that it won't stain them.
Yes, those are G.Skills.
Old January 11, 2012, 09:57 AM
lowfat's Avatar
Dye shouldn't gunk up a loop. Unless it was something like Primochill dye, that stuff will break down. But otherwise you should be fine. The gunk most people see in the loops is more than likely from the fact that they are using Tygon or other crap tubing that has a lot of plasticizer in it. Stick w/ Primoflex LRT tubing and Mayhems for dye, and add a piece of silver to the loop. Do that and you should be golden.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 11, 2012, 10:08 AM
SugarJ's Avatar
It was and it did. Thus my aversion to putting dyes in my $600 loop. I've also used Fluid XP Blood Red when NCIX used to stock it with good results.
Old January 11, 2012, 02:56 PM
supaflyx3's Avatar
If you use enough of it, probably. If you have some around the house theres no harm in trying it if you dont mind destroying a pot.
Old January 11, 2012, 06:02 PM
lowfat's Avatar
Tried food colouring this morning. It didn't work.
Queen of Dreams WIP
Big Lian Li
Complete
Old January 11, 2012, 07:20 PM
supaflyx3's Avatar
Damn :( What would be a strong enough dye for that to work.
Old January 11, 2012, 07:37 PM
lowfat's Avatar
Rit clothing dye. You can get black from well.ca or eBay for other colours if you can't buy it locally. I have some black coming to see if I can get a smoke colour to some tubing. I'll then be dying a keyboard as well.
I hope to buy some of the different blue/red liquids from eBay here shortly if the black turns out well. They are generally about $10/bottle shipped.
Queen of Dreams WIP
Big Lian Li
Complete
Old January 11, 2012, 08:32 PM
supaflyx3's Avatar
Are you going to be dying the entire tube (inside and out) for a deeper color, or plug the tube and just dye the outside of it?
  #19 (permalink)
Old January 11, 2012, 08:38 PM
Birk's Avatar
do you use the liquid or powder RIT dye?
  #20 (permalink)
Old January 11, 2012, 09:43 PM
Silent_Avenger's Avatar
I plan on just getting the outside coloured but it does seem that the easiest way would be to get the darkest red tubing I can find and use red dye in the coolant as well.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
[WTB] 1/2" ID 3/4"OD tubing, anti kink coils, and Swiftech Hydrx Lpfan4ever Buy/Sell & Trade 2 July 18, 2009 01:51 AM
is there a noticable gain to switch from 3/8" to 1/2" tubing? quikgp Water Cooling 8 May 12, 2009 04:26 PM
why does my water cooling seem so "loud"? quikgp Water Cooling 16 April 29, 2009 12:56 PM
Dashocks water cooling with "The Vortex Solution" Dashock Case Mods, Worklog & Gallery 100 June 14, 2008 04:22 PM
where to buy right angle 3/8" BSP Threaded Barb for 3/8" ID Tubing? neurobashing Water Cooling 1 July 4, 2007 10:51 AM
