Old January 10, 2012, 05:56 PM
Default FrozenQ res leak
I'm working on leak testing my parts and I got a frozenQ bay res because it looks sweet but this thing has giving me nothing but trouble.
When I tried installing the DDC pump top the female end to the screw which is a glued in hex came loose and started spinning making the pump top useless... Whatever I poped on my EK top and linked it with a male-male connector.
So move on to leak test, I fill it up and the screw hole for mounting in a 5.25'' bay was drilled too deep and there is a hole into the res.
Now I'll take the hit on the pump top and say I could have tightened too much and stripped it. But leaking from the mounting hole? That's a plain defective product.
So what should I do? Can I fill the hole with hot glue and be happy or will that leech into my loop? Should I RMA?
Old January 10, 2012, 06:18 PM
Ive seen quite a few frozen q's had the leaking issue from the mounting hole.
Seems like a manufacturing defect.
Old January 10, 2012, 07:10 PM
Probably gonna RMA it, which will delay my build till next week. Which I'm scheduled for surgery so I'll be out for a week... Which delays my build 2 weeks. :(
Old January 10, 2012, 07:11 PM
Dazmode's Avatar
This is first one that come trough my hands, but still disappointing.
Orange Build: Final Video
HTPC Build: Final Video
barb on radiator leak CTA Water Cooling 23 February 28, 2011 12:19 PM
EK multioption Res X2 leak mataribot Water Cooling 15 October 28, 2010 07:58 PM
Gamergrub Contest Leak ziikutv Rumor Mill 1 December 4, 2009 08:32 PM
i got a LEAK! kyle_L Water Cooling 9 May 1, 2009 05:10 AM
Leak in T-line Phobia Water Cooling 17 June 9, 2008 04:37 PM
