Old January 8, 2012, 08:26 PM
sswilson's Avatar
Originally Posted by JD View Post
These are a godsend:
Radiator Mounting Screw & Nut, 25mm - Water cooling systems, pc liquid cooling kit, cpu, video card, hard drive
Radiator Mounting Screw & Nut, 38mm - Water cooling systems, pc liquid cooling kit, cpu, video card, hard drive
That's 6/32, so you're fine :)
You can just go to your local home improvement store and get 6/32 screws no problem. I think it's 1-1/4" length that you'd want for 25mm fans.
It's funny how Canada uses the metric system and yet it's damn near impossible to find metric screws in the major chain stores.
Ohhhhh.... shiney..... ;)
I'm assuming that they're long enough to fit either a fan guard over the fan, or to mount to the side of a case?
Old January 8, 2012, 08:55 PM
lowfat's Avatar
Yes you'll be able to fit a grill or mount it to a case w/ those.
Old January 8, 2012, 09:01 PM
Birk's Avatar
1-1/4" length okay, and that reminds me, does that include a fan guard or case mount space? I don't know how much space there is before you puncture your rad, is there a couple mm margin to work with or is it really super easy to go too far
Old January 8, 2012, 09:07 PM
JD JD is offline
1-1/4" would be under the assumption of a case or fan grill along with the fan. If it's just the fan only, it'll likely hit the rad.
However, it depends on how the rad is constructed, just keep an eye on things while you're screwing in the fan. For example, one side of my HWLabs SR-1 has about 1cm between the outer mounting holes and the actual radiator surface.
M4 screws SugarJ Water Cooling 10 December 5, 2011 06:14 AM
where to buys screws and what not Goalieman077 Cases 3 January 7, 2010 02:32 PM
[WTB] Stock HS w/screws for 8800GT/GTS , or Just Screws! Soultribunal Buy/Sell & Trade 15 October 29, 2009 01:48 PM
help with screws phantom_jo Off Topic 9 May 7, 2009 09:41 AM
Thumb Screws WolfBane Off Topic 2 August 4, 2008 05:32 AM
