-   -   Custom Radiator; Second Revision (http://www.hardwarecanucks.com/forum/water-cooling/50227-custom-radiator-second-revision.html)
AmuseMe January 8, 2012 10:29 AM
All Canadian Radiator: Second Revision
So after building my first radiator for my TJ07, I decided to take that idea, and make a good version. Specifically, in a 120.3 spec. I am basing it on the old ThermoChill radiators. I have a 19mm and 25mm coming my way. These will be stripped down for measurment purposes.
IDEAS
1) Built in Fan Shroud. I would add 5/8" overhang on one side of the radiator. This would act as a built in shroud. Example:
http://i1094.photobucket.com/albums/...42/Tanks-1.png
2) Duel G1/4 Ports on either side. This would allow the user to use the built in shroud (5/8") in either push or pull, and have fittings on either side they would choose. Like in this picture:
http://i1094.photobucket.com/albums/.../TopView-1.png
Current Specs
All copper and brass construction
Staggered Tube Design
Tubes are designed to add turbulance to the water
8 FPI of Copper striagt multi lovered fins
G1/4 threaded inserts
Duel-pass
Fan brackets will be made from brushed aluminum with steel threaded inserts for the fans.
Anything else worth consideration?
AmuseMe January 10, 2012 07:20 AM
I want to start this ASAP... Anyone have input?
KaptCrunch January 10, 2012 08:36 AM
1 Attachment(s)
use blind incerts for to make idiot proof (not threaded through, no hole)
and use threaded rod to mount fan, gives option of lenght
AmuseMe January 10, 2012 10:39 AM
That's what I was thinking of using. But then I would need to get specific/ exact length screws for it.
KaptCrunch January 10, 2012 11:22 AM
not really for stud setup once fan is on, just cut excess off an 6-32 cromed acorn nut to cap it
AmuseMe January 10, 2012 12:09 PM
Or I'll just say that one should use 30mm screws for 25mm fans?
