Old March 4, 2007, 06:26 PM
Babrbarossa's Avatar
Default Techarp's Understanding and Mastering Water Cooling Revision 1.1
Here's a new revision of Techarp's watercooling guide- I haven't read it all yet, but so far I'd say that it looks like a good place to start, although if you're new at WC like me, I'd seek advice from Misoprostol before I followed this guide to the letter. Perhaps some of the more experienced water coolers will offer their opinion on this guide in this thread...
"So, you're getting tired of your processor's and graphics card's stock coolers and you start thinking, "What next can I try?". The answer is simple - get an after-market replacement cooler! But which one, you may wonder.
The most common option is to get an air cooler. Air coolers are cheaper and easier to install, but their performance will suffer as dust accumulates, necessitating periodical cleanings. Noise from their fan can also be a really big problem, especially if you are looking for cutting-edge performance which is only possible with insanely fast (and noisy) fans.
But what if we want great cooling performance without the noise? Is that even possible? Yes, it is. Go water-cooling!
What? Are you nuts? Don't those things leak and are a hassle to maintain? Well, providing you are of the conscientious and careful type, it isn't that bad. Good preparation and force of habit are all you need to negate those problems.
"Ah haaa" you may say, "Then I should just get those ready-made water-cooler kits by companies like Coolermaster and Thermaltake, right?"
Bad idea, my friend. Those kits were designed based on rather poor fluid engineering principles, which I will explain later in this article. Therefore, they are the worst kits you can buy. High-performance air coolers beat them both in price and performance.
This guide is intended to prepare you for your first water cooler, and prevent you from making common mistakes in your first foray into the exotic world of water-cooling. So, I'll be covering as many aspects as possible from basic components and what they do to the choices available in the market. I will also discuss a few aftermarket modifications, for those who are itching for custom tweaks."
More from TechArp
psst, wanna see my binder?
Old March 12, 2007, 04:26 PM
This would be a good read, but the link does'nt work.
Old March 12, 2007, 04:30 PM
Patriote's Avatar
Yeah Error loading page!
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old March 12, 2007, 04:50 PM
cyberspyder's Avatar
Heres an equally good one, if not better: Ma***racer's Guide
Old March 13, 2007, 04:10 AM
Patriote's Avatar
Yeah it's probably the best. It's fun to see some XS members in here
• - Noctua NH-D14
Old March 13, 2007, 05:56 AM
It's strange, but it seems to have disappeared- it was very recently updated too. That guide at XS is good- he's pretty dead-set against NB water cooling- I wonder if he'd soften his position if he had a 680i
Old March 13, 2007, 06:25 AM
Patriote's Avatar
Lo0L! The guide i assume has been written 2 years ago. Since that time, things have changed quite fast. See how technology change so fast...heh
• - Noctua NH-D14
Old March 13, 2007, 09:38 AM
Yea, it's been a while since he'd updated that guide (no FuZion etc...), but it's a good read nonetheless. XS rocks!
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
Ram Water Cooling loop Shredder Water Cooling 5 January 24, 2008 08:55 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 09:22 PM
Water cooling build SHaCK Water Cooling 34 April 24, 2007 07:45 AM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
